Originally Posted by vectner
Just a clarification, whether you have a disc in the tray or not is not the only problem. Even with the disc removed, you can brick your unit. The pop up window says "Ensure NO DISC status". that means your player needs to be displaying "NO DISC" on the front before you start the upload. Simply removing the disc when prompted is not enough. You should restart your player with out a disc in to ensure that you have NO DISC status on the player BEFORE you start an update.
This is of course a horrible design flaw, and it seems that Samsung is currently out of boards to replace the ones that break with a botched update. I just received a notice that parts are on back order and my repair will take a little while longer
I had not seen this board prior to the update request. And I did have a disc in the player, which stayed in the machine during the whole process. Fortunately for me, the upgrade proceeded smoothly, and I have not seen any problems.
, my question is this: does anyone know what bugs this latest version of the firmware is supposed to fix?
