Originally Posted by drjrt
I'm purchasing a refurbished 2500 from Best Buy.
Is it correct to assume I will have less wireless-related problems if I
purchase the Samsung Wireless Dongle (WIS09ABGN)?
(I assume I will have to upgrade my ancient wireless router....)
Also, it has to drive a 5meter DVI cable. Anyone have problems with that length?
The Samsung Wireless Dongle is only compatible with the 2009 Samsung Blu-ray players. I am assuming that you are purchasing the BD-P2550 from Best Buy because they never sold the BD-P2500 to the best of my knowledge. The BD-P2550 and BD-P2500 are both 2008 Blu-ray players. You can buy any wireless access point and make any device that has an ethernet port a wireless device. A quick search on Amazon should provide you with several options.
Another option is to purchase an ethernet power adapter kit. This option will allow you to use your houses electrical wiring to transmit the internet. My father-in-law is using this option on his BD-P2550 and this option works great. He purchased the Linksys Kit (200 mbs).. A search of Amazon for "ethernet powerline" should provide you several options.
I believe you should be fine using 5 meter HDMI to DVI cable.
I hope this information helps.
