Originally Posted by
georgemoe
Same thing here with my 2550 and I'm on 2.6. SA was a Netflix disc but Tangled was just purchased.
Due to my above posted issue with Disney discs, I just discovered 2.7 was available. I have the same issue as this older post with the firmware upgrade not working either via USB or CD-R. Any ideas?
I'm going to try and reset the player then try the upgrade again. If that fails I'll be looking for a cheaper ($200ish) replacement. BB has the 6800's available for $199 via their outlet center. I'll have to research.
I had called Samsung and they opted to send me a disc. The only issue was, they sent me a disc for the 1500. Thankfully, it didn't try to install that firmware or it would have potentially bricked my player. However, it didn't say anything like "wrong firmware". It said, "the disc cannot be played". At first, I didn't realize what was wrong until I read the label more closely and realized the issue.
I ended up getting a chance to reinstall Roxio on my new system, so I was able to burn the firmware I downloaded off the web site.
I was finally able to play Tangled, but I almost thought it didn't work when it went to the castle animation for a few seconds before finally loading the disc properly.
