The "Z" Family Theater - Page 9
post #241 of 410
I need to get down there and test drive your setup I'm sure chris would love to check it out also
How about in two weeks? What movie are you thinking?
Originally Posted by GI Joe Sixpack View Post
Hi yamahaSHO,
Your theater is looking good. Are you happy with the Superseal? Can you feel it in any way below the carpet?
Honestly, I hated it for carpet, so I didn't put it in. It's great for something like a laminate floor or if you were to put OSB/plywood over it before carpet.
post #242 of 410
You've got the same problem I do.... Horror movies are rough with the doors behind you! I watched "The Ring" sideways with one eye on the door and one on the screen.
Chairs look good! Glad to hear the RF62II is working out.
post #243 of 410
Ironman 2 and Robin Hood will be out by then maybe one of those
post #244 of 410
Sounds good. I need to play with sub placement as my bass is a few feet in front of the seats or the rear of the room.
post #245 of 410
I must have mis-interpreted your pictures. Some of them showed it below your stage so I assumed you had used it for the entire theater floor. Did you not put it down after all? Or did you try it with the carpet and then pull it out because it didn't feel right? I'm really interested because I was strongly considering using it. What did you put down in its place?
post #246 of 410
I did lay it down under the stage as I was going to do the whole room. I like that it lifts the sand up a bit off the floor even though it is in plastic. Once the sand was down, I wasn't going to remove the Superseal, especially since I sealed the edges with Liquid Nails.
I originally was doing a laminte floor in the closet, but wasn't happy with the lumpy concrete, even after 'leveling' it. The Superseal did work very well under the laminate. I wasn't trusting enough to put it under carpet after I put the Superseal down. I pulled it up just before carpet went in.
The pad is resting directly on the concrete. It has a plastic coating on it to keep it from absorbing water though (and is the best pad I've ever walked on).
post #247 of 410
Winter weather is here, so I'll be finishing the last of the little "finishing" stuff on the theater and basement. For now, it's getting plenty of use! We just picked up a Kinect and it's pretty fun!
Yes, you too can look like some ratards!
post #248 of 410
We picked it up for the kids for Christmas so we have not broke it out yet but it looks like alot of fun
post #249 of 410
I hope it plays well with a dark room and a projector! I want to get the sports game.
When do you guys want to come over? I'm not completely done, but it plays movies like it is!
post #250 of 410
One of these weekends your not busy probably a Friday or Saturday night would be best
post #251 of 410
How about this Friday night? What movie do you guys want to see?
post #252 of 410
Hey.. Can I ask how that All-In one floor worked out?
Does it make noise?
My floor isn't leval I know that already... There are old vinyl tiles on there that I wanted to leave and just go right over... I'm not that particular to leveling and all but, I do want to avoid mold..
Or is the leveling issue just going to kill it?
tks
post #253 of 410
Does it make noise?
tks
I actually pulled it all out as the carpet was going in. I followed the instructions that the supplier gave me to run it all the way to the wall and put the carpet tacks through it. This is different than the instructions from the site.... I couldn't flatten it out and I wasn't comfortable with it even when following the manufacturers instructions, so I just laid the pad directly on the concrete. I was concerned with feeling the plastic underneath and having it push up on the carpet.
I can't really give any advice as if it were to work well installed per the manufacturer's notes, but when I laid it under laminate floor, it was awesome IF I could get the floor COMPLETELY level. I could not do that where I was (easily) so I just used carpet through the entire basement.
Personally, I think this would work best with laminate/wood floors or for carpet if you used some plywood or OSB over top of it. For the latter, I think there are better options.
This is IMHO and YMMV.
post #254 of 410
Originally Posted by Happytobehere200 View Post
What type of SHO? Sounds dumb but I know of the Tarus SHO but wasn't there a Mustang too?
No, there's no SHO Mustang, but yes, I have a Taurus SHO (hence the screen name).
They did make a SVO Mustang during the years of 1984-1986. Here's a link to a SVO site.
YamahaSHO - Love your build!!!
dbl
post #255 of 410
Yup, SVO's are pretty cool. I've got a buddy up in Colorado that has a pretty nice one he's building up. He's also the guy that rebuilt my trans in the SHO to handle the extra power a little better.
post #256 of 410
I tried to do some screen shots today, but the point and shoot I used didn't turn out too well. I'll have to break out the DSLR here soon.
Shoehorned this mamajama in.
Everything can use moar SHO!
post #257 of 410
Screen Shots look fine.
That's a nice model reproduction of that Yamaha (I mean Ford) V6
post #258 of 410
Screen shots look good. I have never seen Avatar. Everyone seems to like it, maybe someday I'll watch.
post #259 of 410
I generally don't watch these type if movies, but after I watched about 30 minutes of it at Scott's (W00lly) house, I had to finish it. It is a pretty good movie; I've watched it a few times now.
post #260 of 410
I generally love sci-fi movies, but for some reason this one has no appeal to me. Maybe I can blame George Lucas and his evil Jar Jar Binks for making me shy away from films like this.
post #261 of 410
Haven't been on the forum for a while but it looks like you have made some good progress. Have you seen The Hurt Locker. If not it's a great movie for a home theater. It will give those Klipsch a good work out. ..... I might have to go watch that movie now.
post #262 of 410
Yup, I've seen it. It's a good movie. I need to stop watching movies and playing games on it and finish it. Last night a buddy and I nearly pulled an all-nighter on Gran Turismo 5.
post #263 of 410
Just wait till we get to watch this in our theaters. Make sure you change the rez to 720p and watch in full screen I do believe I will be going to see this in IMAX when it comes out.
http://www.youtube.com/watch?v=brBuIeH0vfg
post #264 of 410
Wow , can't wait for this movie !
& BTW Nice work on the Build YamahaSHO ! SVS RulZ
Mike
post #265 of 410
I'm going to wait until you get it on BD. I say that as it's not necessarily a movie I would watch, but you've shown me a few that I didn't think I'd like, but loved.
Mike
Thanks, I get both PC12-NSD's tomorrow!
With that said, I could use some thoughts... I've been searching, but wouldn't mind some opinions on my setup. Now that I've ditched the Klipsch subs, I do have two SVS PC12-NSD's due to arrive tomorrow. Both of these subs will be up front behind the screen/screen wall. I recently acquired a new Klipsch RW-12d woofer (thread) and will be building a sonosub out of it just because I have always wanted to build one.
With the Klipsch 12" sono, I was planning on putting the sub at the rear-corner of my room with an Outlaw wireless deal. The SVS up front will be run off of a single Anti-Mode 8033c (which works great, BTW). Would it be worth it to invest in a second Anti-Mode for the rear sub and calibrate it separately, or would I need something that can account for both the SVS and sono playing together? My thought was if I can calibrate them separately, they may play 'better' with each other. Any thoughts?
Both the SVS and Klipsch sono use 12" woofers of comparable power handling and the cabinets will be roughly the same size.
post #266 of 410
HOT chicks shooting guns and rocket launchers come on whats not to like
post #267 of 410
Jason,
I will be watching your thread closely for your impressions of the new PC12-NSDs. Will also be interested to hear your impressions with 3 cylinders in your room.
I am awaiting the shipment of a 16-46 PC+, this will supplement the 2, 20-39's I am already running. Configuration I will try is: 2 up front and one centered in the rear.
post #268 of 410
SVS said for me to place the subs right next to each as they sound best there of coarse I placed the on both ends of the room as that seemed best to MY thinking but Jack @ SVS was right they sounded Best right next to each other
one thing SVS will do for you is that if U send them a layout of your room they will tell where best to place the subs that's what I did ,PLUS they can advise on the setup of the Antimode 8033c save Ya self time for more Movies !
L O L
Keep up the great work & MORE PIX plz !
post #269 of 410
I suppose if I don't agree with you, my MAN-card will be revoked?
You do have a point
Jason,
They just came in and I unboxed them. I'm letting them warm up to room temp until I power them up. I will have to build my 3rd sub soon. I need to order a router bit and circle jig so I can make my circles. I won't be able to put the rear sub in the center of the back wall, so I'll play with corner placement on both sides.
post #270 of 410
L O L
Are you talking about collocating them for more output? I had output before, just dead spots in the room, plus the Klipsch made all kinds of weird noises with there plastics.
The 8033 literally sets itself up, what did SVS advise with yours, assuming you have one?
Do you have a picture of your setup?
Here's a quick iPhone pic. I will be installing LinAcoustic today.
