/\\ What he said
If you want to look further into building one of these, do a search on this forum, Home Theater Shack, and/or Google for "Sonosub" and you'll find LOTS of these builds. Mine is very, VERY tiny compared to many of the builds out there. Also, check out the link below for sizing your build.
http://www.subwoofer-builder.com/sonosub.htm
You can use it in conjuction with WinISD (also freeware) to help really fine tune a setup.
EDIT: BTW, where in Iowa are you located?
