Originally Posted by pfp
I'm definitely planning to use mouse ears on the screen wall and ceiling. Doors and trim will be black as well. My issue right now is deciding on a color for the remaining walls. I really like colors like what you are using (caramelized onion is one of the many samples I picked up from Lowes yesterday) but I'm concerned about going so light.
Right now my ceiling is white and all walls are very light tan. Light control in the room is really good but I'm currently getting alot of reflection off the ceiling and side walls (I don't have a screen up yet so perhaps that will help some too). I'm seeing enough of you guys doing colors like this in rooms MUCH nicer than mine will be so I'm guessing it must not be an issue.
I'm going to make it a point to make sure Caramelized Onion is the paint I used so that I don't tell you wrong... but when you get rid of all the whites/light colors and have something like the CO and black paint, it's not very light. Paints always seem darker once the entire room has been painted.
I'm curious on the black paint - how many coats did you need to use?
After using some cheap primer/paint to be soaked up by new drywall, I *think* I only put two coats. The Mouse Ears covers VERY well. When my buddy helped me paint my false wall framing, he was very surprised at how well it went on.
I'm currently in northern Peoria but I transplanted from LA (where I'm from) about 6 years ago.
I grew up in Litchfield Park
