*** Scroll down for Calibration reports
Time to start a stand alone owners thread for this model now that people are starting to get them in hand and installed.
So if you own the 141 take some pictures and post your impressions here. Maybe the 141 vs 151 thread could be merged here, but a "vs" thread is not what I am interested in nor is it the purpose of this thread. This is a stand alone 141 owners thread.
Useful Specs:
481 Watts (0.3 W Standby)
2.5"
Subjected to a 100 hour break in period at the factory
Mounting Holes: 33 15/16" by 19 11/16"
http://www.pioneerelectronics.com/portal/site/EC/
RS-232 codes:
Calibration:
list of ISF Calibrators who can calibrate the 141
http://www.avsforum.com/avs-vb/showp...postcount=1663
While I totally recommend using ControlCal or getting a pro to calibrate your display since Pioneer does not allow you to have access to all adjustments this way, buts its still interesting to know how you can access the ISF mode via your web browser. This works on both Euro and north american units.
Networking Info:
(here is what I did)***anyone in my area who would like to hire a networker that is familiar with setting this feature up please send me a PM and ill pass on his info
1.) Bought Apple Aiport Express
2.) Connected 141 to the network (hired computer networker)
3.) Once connected I was able to access all the control menus excpet for ISF mode which requires a password. See above for how to access.
4.) Setting up the email function was a little tricky. My best guess is that what you are required to enter is in fact labled wrong.
------I did not need to put in an ID or password
-----"Mail server SMTP" is actually for the Mail Server IP address
-----"Sender Address" is for your email address
----- There is no DNS built into the email
5.) Once you get your IP address for the display type it into the browser. The manual suggests you should only use Internet Explorer, but I can confirm you can also use Safari. Remember to turn off Pop up blocker
Here is the info which comes on a test email and any update email you request:
Transmission trigger event : TEST MAIL
Model PRO-141FD
Name ****
Location Home
Installation date 8/29/08
Serial number HHPM000****
Usage time 000042 hours
Service code -05M ***************
Power status OFF
Power count 00018
INPUT INPUT5
Signal ********* ***.*
Temperature Temp1 :*** Temp2 :000
Temp3 :000 Panel :000
Failure information SD/PD :
1st : 2nd :
Operation record
1st Power off 000042H 28M
2nd Power on 000042H 28M
3rd Power off 000042H 30M
4th Power on 000042H 30M
5th Power off 000042H 33M
Compatible mounts
Because of the unique spacing of the mounting holes with the 141 it can be a litle tricky finding mounts. Here is a list of wall mounts which work with this display.
Sanus VMPL3: Comes with low profile (1.5") AND tilting attachment (2.5). You use one or the other.
http://www.sanus.com/ca/en/products/...delCode/VMPL3/
Peerless PLA60: Articulating wall arm, you need the adaptor plate too (PLP-NEC61)
http://www.peerlessmounts.com/en/dyn...60/u/f/av/8470
Peerless SA760P
http://www.peerlessmounts.com/en/dyn...66/u/f/av/8470
Pioneer KRP-WM01
http://www.pioneerelectronics.com/PU....KRP-WM01.Kuro
Omni Mount U3 Tillt
http://www.omnimount.com/consumer/pr...f-328aab22a448
OmniMount ULPTX (low profile)
http://www.omnimount.com/consumer/pr...0-f854d5c0ad65
OmiMount Architectural cantilever
http://www.omnimount.com/consumer/pr...9-cde15c17b785
Pictures of my install
It arrives
It was such a nice day and a cruise ship was just leaving when I finished so I snapped a pic
Calibration Reports
Useful Specs:
2.5"
Originally Posted by Bogney Baux
Here are my Pure Cinema refresh frequency results for each setting on the PRO-141FD.
Advance
480i 60 - 71.93 Hz
480p 60 - 71.93 Hz
720p 60 - 71.93 Hz
1080i 60 - 71.93 Hz
1080p 60 - 59.94 Hz
1080p 24 - 71.93 Hz
Smooth
480i 60 - 59.94 Hz
480p 60 - 59.94 Hz
720p 60 - 59.94 Hz
1080i 60 - 59.94 Hz
1080p 60 - 59.94 Hz
1080p 24 - 59.94 Hz
Standard
480i 60 - 59.94 Hz
480p 60 - 59.94 Hz
720p 60 - 59.94 Hz
1080i 60 - 59.94 Hz
1080p 60 - 59.94 Hz
1080p 24 - 71.93 Hz
Off
480i 60 - 59.94 Hz
480p 60 - 59.94 Hz
720p 60 - 59.94 Hz
1080i 60 - 59.94 Hz
1080p 60 - 59.94 Hz
1080p 24 - 59.94 Hz
Advance
480i 60 - 71.93 Hz
480p 60 - 71.93 Hz
720p 60 - 71.93 Hz
1080i 60 - 71.93 Hz
1080p 60 - 59.94 Hz
1080p 24 - 71.93 Hz
Smooth
480i 60 - 59.94 Hz
480p 60 - 59.94 Hz
720p 60 - 59.94 Hz
1080i 60 - 59.94 Hz
1080p 60 - 59.94 Hz
1080p 24 - 59.94 Hz
Standard
480i 60 - 59.94 Hz
480p 60 - 59.94 Hz
720p 60 - 59.94 Hz
1080i 60 - 59.94 Hz
1080p 60 - 59.94 Hz
1080p 24 - 71.93 Hz
Off
480i 60 - 59.94 Hz
480p 60 - 59.94 Hz
720p 60 - 59.94 Hz
1080i 60 - 59.94 Hz
1080p 60 - 59.94 Hz
1080p 24 - 59.94 Hz
RS-232 codes:
Calibration:
Originally Posted by andrewfee
On the European models (KRP-M) I found that you can get into the ISF section by logging into the regular web interface and then going to:
http://your_kuro_ip/cgi/isf.cgi
as this bypasses the password page.
The options available are:
Originally Posted by turbe
EZ Hours:
Enter this in your Browser (Internet Explorer recommended)
http://Monitor_IP_Address/cgi/service_right.cgi
EZ Hours:
Networking Info:
Model PRO-141FD
Name ****
Location Home
Power status OFF
Power count 00018
INPUT INPUT5
1st : 2nd :
Operation record
Compatible mounts
Peerless SA760P
Pioneer KRP-WM01
Omni Mount U3 Tillt
It arrives
Calibration Reports
Originally Posted by sillysally
Pioneer 9G Elite Monitor 141 ISF-Night Settings.
I used a Oppo BDP-83 for these settings
Oppo Setup for Blu Ray films 1080P@24
Picture Adjustemnt-Default
Primary Output-HDMI
TV Aspect Ratio-16:9 Wide
TV System-NTSC
Output Resolution- 1080P or Source Direct
1080p24 Output-On
DVD 24p Conversion-Off
HDMI Options-Film Bias Mode, Cue corection Off,
Color Space YCbCr 4:2:2, Deep Color Off (dithered), Demo Mode Off,
A/V Sync 0
Oppo setup for SD Films Auto with these settings.
Output Resolution-Auto
All the rest of the Oppo setup settings are the same.
Picture Settings:
AV Selection: ISF-Night
Contrast: 24
Brightness:-1
Color: +4
Tint: 0
Sharpness: -15
Pure Cinema: 2 (Advance)
Black Level: 0 (Off)
CTI: 0 (Off)
Color Space: 2
Color Temp: 6 (Manual)
Screen size 0 (Dot By Dot)
ACL: 0 (Off)
3DYC: 2
I-P Mode: 2
Text Optimization: 0 (Off)
Intelligent Mode: 0 (Off)
DRE Picture: 0 (Off)
Enhancer Mode: 1
Block NR: 0 (Off)
3DNR: 0 (Off)
Field NR: 0 (Off)
Mosquito NR: 0 (Off)
Power Save Mode: Off
Orbiter: Mode 0 or you can turn on
RGB Controls
R High: 0
G High: 0
B High:+16
R Low: =2
G Low: 0
B Low: 0
Color Management
R: 0
Y: +1
G: 0
C: 0
B: 0
M: -1 or -2
Gamma
10%R 0
10%G 0
10%B 0
20%R 0
20%G 0
20%B 0
30%R 0
30%G 0
30%B 0
40%R 0
40%G 0
40%B 0
50%R 0
50%G 0
50%B 0
60%R 0
60%G 0
60%B 0
70%R 0
70%G 0
70%B 0
80%R 0
80%G 0
80%B 0
90%R 0
90%G 0
90%B 0
Template by D-Nice
Primary Output-HDMI
TV System-NTSC
1080p24 Output-On
A/V Sync 0
Picture Settings:
Contrast: 24
Brightness:-1
Color: +4
Tint: 0
Sharpness: -15
CTI: 0 (Off)
Color Space: 2
ACL: 0 (Off)
3DYC: 2
I-P Mode: 2
Enhancer Mode: 1
Block NR: 0 (Off)
3DNR: 0 (Off)
Field NR: 0 (Off)
RGB Controls
R High: 0
G High: 0
B High:+16
R Low: =2
G Low: 0
B Low: 0
Color Management
R: 0
Y: +1
G: 0
C: 0
B: 0
M: -1 or -2
Gamma
10%R 0
10%G 0
10%B 0
20%R 0
20%G 0
20%B 0
30%R 0
30%G 0
30%B 0
40%R 0
40%G 0
40%B 0
50%R 0
50%G 0
50%B 0
60%R 0
60%G 0
60%B 0
70%R 0
70%G 0
70%B 0
80%R 0
80%G 0
80%B 0
90%R 0
90%G 0
90%B 0
Template by D-Nice
It's already taken over the elite owner's
