Originally Posted by baddgsx
Kevins Controlcal software was being buggy when doing my Calibration. With the PS3 as my bluray player , using the software it showed that i was clipping white at any contrast setting. But not using the software we can easily see that my PS3 did not clip white. Very weird!!!
I have a copy of controlcal and still am waiting for my usb to serial adapter. Once i get that ill check out what changes he exactly made. I might turn the sharpness up since i didnt notice edge enhancement by my eye until it was at -8 , and Kevin likes it at -13.
I would tend to agree with Kevin, about his setting for sharpness in non ISF mode. I will check ISF mode tonight and see if I can raise sharpness from -15 to -13.
As far as "clipping the white" . I am sure Turbe can explain what is happening better than I can. However my take on this is, when you enter ISF mode everything changes. And yes I can understand why Kevin would have problems with luminance in ISF mode. But I have never seen a problem because of using controlcal software. Also the problem with closing ISF mode (closing controlcal), you would not be able to use the ISF modes to calibrate for these modes. Unless Kevin has found a different way to access ISF modes.
So the question is, do you have a good calibration in ISF mode. How did Kevin over come the problem in ISF mode, using your PS3 ?
