AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Signature Elite 141 Owners Thread
Signature Elite 141 Owners Thread - Page 58
post #1711 of 5267
Does anyone have any Pure settings I could use as a starting point? After doing some searching, I can only find ISF settings.
It will be a little bit before I can this thing calibrated by a professional, so I am just looking for something to tide me over. Thanks!
post #1712 of 5267
Originally Posted by vancouver View Post
true...but one cant deny there is a reference. How much you deviate from that reference is personal choice...you cant really set the screen to what ever you like and then refer to it as professionally calibrated. Or calibrated under ISF or THX standards etc. Proper calibration is really "what you personally like". True calibrations is setting the display to a standard.
Yes you are right, you cant claim a "professional" calibration. However you can claim "calibrated under ISF or THX standards etc", if you have the tools and some knowledge of how to use these tools. I have seen two "professional" calibration settings. These settings are much different, however the end result is close. Why I point this out is because if you use ISF or THX standards, there is no one right way to calibrate. Calibration imo is more of a art than a exact science.
btw; Folks should understand, and as you pointed out should know that by changing any of the settings for the most part will negate there "professional" calibrations. There are exceptions to this rule of course.
post #1713 of 5267
Do you guys use advanced mode also? I definitely see more motion blurr, or judder, with subtle face movements compared to leaving it off.
post #1714 of 5267
honestly I prefer smooth. It studders a little on the odd pan, but for the most part it provides a very motion blur free picture. I find it reduces viewing fatigue. Reminds me of an effect a friends B&O avent CRT use produced which I always wanted from a plasma.
post #1715 of 5267
Originally Posted by petmic10 View Post
I would have to respectfully disagree with this. Enhancer 2 and sharpness
at 0 adds way to much edge enhancement on test patterns and on actual
content to my eyes anyway.
Interesting. With content i have a hard time seeing a difference. Although it's not exact. All i can say is with content at a normal viewing distance the sharpness is similar with those comparisons i gave when looking at the actual picture. Of course i dont like it that sharp so i use enhancer 2 with sharpness some, but definitely not at 0.
post #1716 of 5267
honestly I prefer smooth. It studders a little on the odd pan.
Yeah smooth can smooth things out, but has some of it's own artifacts, and like you said that occasional pan that makes things stutter. For me that's unacceptable. I would rather see the judder than studder There's definitely some improvements to be made with that mode.
post #1717 of 5267
true....but you have to admit that 90% of the time it creates a great picture. Watch the opening of Hulk when it pans up the city buildings with smooth. There is absolutely zero motion blur.
by the way for those curious Smooth is still playing at 72Hz
post #1718 of 5267
For me the motion just seems odd, no matter how smooth it can look. I dont want to worry everytime the camera pans that smooth is engaged and to look how smooth it is. Or hope a scene dont come on where everything is stuttering like crazy. I can see how some will like it though.
post #1719 of 5267
I have succesfully used an IR repeater system from Speakercraft and had great success. I am distributing to two other satellite boxes and my preamp as well as have other rooms connected into the system for those remote applications.
Originally Posted by Ijon_Tichy View Post
Has anyone tried the IR Repeater yet?
Will it control nonPio devices?
post #1720 of 5267
You got it. Post below has my latest settings, in pure mode.
There is also older settings I posted for Pure mode. I think in October.
I would suggest you also try ISF mode settings. That way when you have your 141 calibrated, you should have a good idea how you want it calibrated.
post #1721 of 5267
Please do not post these settings.
Pioneer Elite 141 and Pioneer BDP-51 settings on the BDP-51,
Source direct, High Speed, User setting, White-1, Black +1
If you use these settings in any thing other than a 1080P source, you will have to enter these setting for what ever the source res you are using.
Picture Settings:
AV Selection: Pure
Contrast: 26
Brightness: 0
Color: +3
Tint: 0
Sharpness: -15
Gamma: 5
Pure Cinema: 2 (Advance)
Black Level: 0 (Off)
CTI: 0 (Off)
Color Space: 2
Color Temp: 6 (Manual)
ACL: 0 (Off)
3DYC: 2
I-P Mode: 2
Text Optimization: 0 (Off)
Intelligent Mode: 0 (Off)
DRE Picture: 0 (Off)
Enhancer Mode: 2
Block NR: 0 (Off)
3DNR: 0 (Off)
Field NR: 0 (Off)
Mosquito NR: 0 (Off)
Power Save Mode: Off
Orbiter: Mode Off
RGB Controls
R High: -1
G High: 0
B High: +8
R Low: -1
G Low: 0
B Low: -1
Color Management
R: -3
Y: +1
G: 0
C: +1
B: 0
M: 0
BD51 and 141, Pure Mode.pdf 85.048828125k . file
BD51 and 141, Pure 1.pdf 68.30078125k . file
post #1722 of 5267
I too sometimes like 'smooth', but it does produce the occasional, very weird artifact. But again, the smooth effect is probably another of those 'deviations' from what the actual film looked like. Using smooth does bring the movie into a more 'video-like' appearance.
We can argue as to whether judder was the 'director's intent' or simply a limitation of film technology. Either way, smooth does bring about a bigger 'delta' from how the movie appeared in theaters. In actuality, if you think about it, how is using 'smooth' any different than deviations of color, sharpness etc. from the correct ISF calibration? Granted judder is not part of any standard, but nonetheless it is introducing something that wasn't there in the original. Fun stuff.
post #1723 of 5267
I just ordered the 141 from my local dealer to replace my Fujitsu P50 and it should be here in about one week.
Got it for a decent price, plus a WAF surcharge.if you know what I mean.
post #1724 of 5267
Im having trouble getting the controlcal to power on my 141.
Says , COM4:9600:NONE:1:FLOW=N and when i hit power on it says sent and nothing happened.
I have the keyspan turbe recommends set to com 4 and the tv is set to 9600
Im using a null modem adapter ,is that ok?
any help is appreciated , thanx Chris
post #1725 of 5267
I think you have to take the null modem adapter out the mix.
post #1726 of 5267
That Null Modem Adapter is your problem...
If you had a Null Modem configured serial cable to go with the adapter, it should work as well.
post #1727 of 5267
Congrats! And yes we know about the surcharge lol
post #1728 of 5267
I have updated my settings post for my BD-51 and 141. I have added my raw data reports. I was able to set the luminance curve fairly close with these settings. This time I set my BD-51 to user, -1 white. I did use Gamma 5. However there was a strange thing going on with the Luminance, and hence the lower gamma point.
post #1729 of 5267
thank you totalownership and turbe. I got it to work. Im very happy that i figured out why my isf settings was not showing above white and why my standard mode settings were on my PS3 with super white enabled.
If u want above white to show up clearly u need to have any of the DRE Picture settings on. but now theres a trade off with that. I guess ill have to see which i like best or if i can see a difference. Im going to try low.
post #1730 of 5267
The Pioneer Elite KURO monitor web site is working again. You can get your factory white balance settings there.
post #1731 of 5267
Did you use the 141 as the receiver?
I'm hoping to just plug in some cheap emitters into the 141.
post #1732 of 5267
OK, I'll bite: WAF surcharge????
post #1733 of 5267
stacy,
I had to scratch my head about WAF too. Then I remember the "Wife Approval Factor" which probably means jrannison had to buy something for his wife in order to get her approval for the 141 purchase. Thus the WAF surcharge. It can become quite expensive as wives get anything from jewlery to room additions.
post #1734 of 5267
Originally Posted by JimP View Post
stacy,
I thought there would be some head scratching on my statement, in particular the single folks.
Actually I got off easy.....................I have to update the small bathroom. There were no high demands because she also appreciates a good picture, being an artist and all.. She just cares less about all the technical stuff.
post #1735 of 5267
I'll need to look into this too since I have a PS3 and 141. I probably should just search, what pattern/test disc are you using again (and which pattern specifically?
sillysally, are you experiencing any issues with your BR Players?
post #1736 of 5267
Its the 1080p grey ramps pattern on the bluray version of DVE. This WTW behaves the same way on any other mode , like standard mode , etc...
So its not the controlcal software , its the 141 that behaves this way.
post #1737 of 5267
Thanks! I appreciate it.
post #1738 of 5267
Being married and in the business I knew exactly what you meant
post #1739 of 5267
another weird thing happened while i was checking out which i liked better , advanced or smooth. I was using the just the remote to play with the smooth and advanced settings on my standard mode because i didnt feel like plugging in the laptop to use controlcal. I finally figued out which i liked best and wanted to go back to my ISF day mode and IT WAS GONE!!!!
I dont know what happend but my ISF day mode isnt there. The night mode is still there though. What should i do? I backed up these settings on my laptop.
HELP!! How do i get this mode to show up again? Can it be done using the remote or do i have to use the laptop again?
Thanx Chris
post #1740 of 5267
Yes you did get it quick
