Originally Posted by PeteST
Yeah, I don't have ControlCal and my monitor has not been professionally calibrated yet. Therefore, I do not have access to the ISF modes yet.
I understand what you are say about the 141 adjusting to the resolution during playback of copyright warnings, etc... and then switching back to "Dot-by-Dot" during playback of the main feature. However, this does not explain why when I pop in the next blu-ray disc, my 141 will switch itself from "Dot-by-Dot" to "Auto" (and remain in "Auto" mode) even when the movie itself is playing. Any other ideas or suggestions? My set-up is nothing unusual. Therefore, is this normal behavior for the 141?
Ok, very easy to determine. When viewing a BD film (1080P@24) just press your A/V button on your remote once (1 time only) then see what the pop up box in the upper left hand side of your screen says. If you have your 141 set properly, it should say "Dot-by-Dot", 36bit, 1080p, ect.
Also keep in mind that if you are viewing something like a concert chances are its 1080i, even if that concert is on a blu ray disc.
Using the ISF modes on your 141, makes things a lot easier. And also will bring out the best in your display.
I do have my ISF mode settings posted along with my reports. The link (see below) is for a BD-51 and my 141, if you look at the bottom of my post I also have links for more settings using different BD/HD players.
http://www.avsforum.com/avs-vb/showt...7#post15546767
