AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Signature Elite 141 Owners Thread
Signature Elite 141 Owners Thread - Page 2
post #31 of 5267
Does anybody know if the PRO 141FD will mount to the Chief PSB2043 bracket?
I was hoping to have the Chief PNRIW200B inwall mount installed with my 141.
Are the mounting holes different with the 151 vs the 141?
post #32 of 5267
The manuals don't provide that information, so hopefully one of the owners that has a 151 could measure the distance between mounting holes on the back to be certain if they are the same. I'm pretty sure they are.
post #33 of 5267
Maybe we should call this thread "How will I mount my new 141"
post #34 of 5267
It is relevant to the thread, since the PRO-141FD does not come with a stand or mount of any kind.
That being said - I can't wait to see vancouver's pics.
post #35 of 5267
151 mounts will work with 141's, unless someone can prove me wrong
post #36 of 5267
Originally Posted by Johnny Dunn View Post
Hi Ken,
Have you thought about a gaming console for pix? Also will do music, movies/videos, AND pictures from your pc to your t.v./AVR.
Wireless, so probably 1 step back, but with extras, 2 steps forward (esp PS3).
It's an idea Johnny, but I hate to have an extra device to fill just this void. I'm planning on the Pioneer Elite SC-05 to replace my Panny BD30, so I'm really set for BD playback. But I see your point and I guess if all else failed and I decided to go with the 141, it is an option.
post #37 of 5267
You are going to buy a receiver to replace your blu ray player? I think you meant BDP-05FD
post #38 of 5267
Gosh, I hope so!
I had my Chief PNRIW200B with the 501 box installed last week. It would be a shame to have to remove it after such an effort & expense was made. The 141 will stick out only 1.5" from the wall when retracted
I will put a trim box around the opening so when you look at it from the side you don't see the bracket at all
Here is a pix with the PSB2043 bracket attached (really gets attached to the plasma first then the PNRIW2008, but you get the picture).
post #39 of 5267
Gosh, I hope so!
Do you mean that the TV will be absolutely flush against the wall?
I'm not sure you can have the TV absolutely flush to the wall like that. There needs to be some sort of space for air circulation otherwise it may overheat the TV.
Correct me if I misunderstood what you want to do.
post #40 of 5267
Its up!
I am just finishing the an wall speakers and cabel hidding. I dont know what the 151 came with but the literature with the 141 is pretty cool.
need some more time then ill post pics.
post #41 of 5267
No, this in-wall bracket fits recessed in the wall just shy of 4", so you have enough room for electrical box *& cables (see pix). See chief website for more info. With mount sticks out .61" when retracted and it extends 24". When you add the bracket and mounting screws and you end up 1.5 inches from the wall.
Assumiing the 141 will fit this 2043 bracket.....
post #42 of 5267
No, this in-wall bracket fits ressesed in the wall just shy of 4", so you have enough room for electrical box *& cables (see pix). See chief website for more info. With mount sticks out .61" when retracted and it extends 24". When you add the bracket and mounting screws and you end up 1.5 inches from the wall.
According to their site it should fit. So you should be A Ok.
post #43 of 5267
You are correct! But ironically the BDP is on my list too.
post #44 of 5267
So what are you going to be using as a BD player until then?
post #45 of 5267
Originally Posted by vancouver View Post
Its up!
Tonight - PLEASE!!!
post #46 of 5267
First post updated with pics
post #47 of 5267
Nice pics! And a very nice setup as well.
What's your IP address? I want to turn on your display and tweak it a bit.
Just kidding.
Do you have any devices attached yet so that you could demonstrate the picture?
post #48 of 5267
^^ OMG, thanks for the pics!
By the way, amazing place you live!
post #49 of 5267
Amazing... How is the PQ??? Buzz?? Blotches?? WOW!!! AMAZING. I like the little plaque thing. Nice cruise ship.
post #50 of 5267
Simply beautiful! And yes BC is beautiful as well
post #51 of 5267
Wow!!!!
post #52 of 5267
ok while wife watches iron ched america I can answer some question and I have some to ask too!
Buzz? Nadda! none! ziltch! Even with a pure white screen I could hear a mouse fart from accross the room with my ear right next to the display.
Out of the box from what I can see the display is set to "standard". I guess I can post some numbers if anyone cares, but to my eyes coming from a professionally calibrated Fujitsu I can say its not calibrated correctly. To much contrast all color settings are set to "0"
PS thanks for the compliments.
I dont have the break in disc or images. I just found out that i cant play the images from USB (which I planed) through my Oppo so I ordered the disc and need to wait for it to arrive. Any suggestions on what I should put the picture to while I wait?
I guess Ill have to do some hunting in D-Nice's Settings thread.
post #53 of 5267
Throw in D-Nice's settings for 111/151 (should be the same), and see what it does. What about blotches? WOW!
post #54 of 5267
would blotches be obvious? If so I dont see any. Honestly I havent given more then 20 minutes of watching yet.
Are y ou suggesting the settings he suggests after the break in?
post #55 of 5267
D-NIce Reference settings before break-in (right??)
AV Selection: Pure
Contrast: 36
Brightness: 0
Color: +3
Tint: 0
Sharpness: -15
Pro Adjust
Pure Cinema
Film Mode: Advance
Text Optimization: Off
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 1
Gamma: 1
Color Detail:
Color Temp: Manual
R High -3
G High 0
B High -2
R Low 0
G Low 0
B Low +1
CTI: Off
Color Management
R 0
Y +1
G 0
C -2
B 0
M -2
Color Space: 2
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full
Power Save Mode: Off
Orbiter: Mode 2
And if you are doing break-in...
Recommended 150 Hour Break-In settings for Pioneer 111FD/151FD (ONLY to be used with Evangelo2's Break-in DVD or Thumbdrive Files!!!!!!!!)
Picture:
AV Selection: Sport
Contrast: 50
Brightness: 0
Color: +20
Tint: 0
Sharpness: 0
Pro Adjust
Pure Cinema
Film Mode: Off
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 2
Gamma: 2
Color Detail:
Color Temp: High
CTI: Off
Color Management
R 0
Y 0
G 0
C 0
B 0
M 0
Color Space: 2
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full
Orbiter: Mode 1
Then once you finish break-in... A host of settings (use the first settings or use the other settings for the viewing needs)
Pioneer 111FD/151FD Reference Settings (ONLY use these settings after the 150 hour break-in period!!!!!!!!!)
***Updated 8/1/08***
Picture:
AV Selection: Pure
Contrast: 37
Brightness: 0
Color: +2
Tint: 0
Sharpness: -15
Pro Adjust
Pure Cinema
Film Mode: Advance
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 1
Gamma: 2
Color Detail:
Color Temp: Manual
R High +1
G High 0
B High +4
R Low -2
G Low 0
B Low 0
CTI: Off
Color Management
R -2
Y +1
G -4
C -2
B 0
M -1
Color Space: 2
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full
Orbiter: Mode 2
Pioneer 111FD/151FD D55 Settings (ONLY use these settings after the 150 hour break-in period!!!!!!!!!)
Picture:
AV Selection: Movie
Contrast: 37
Brightness: 0
Color: +3
Tint: G1
Sharpness: -15
Pro Adjust
Pure Cinema
Film Mode: Advance
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 2
Gamma: 2
Color Detail:
Color Temp: Manual
R High +5
G High 0
B High -6
R Low -3
G Low 0
B Low -1
CTI: Off
Color Management
R -2
Y +1
G -4
C -2
B 0
M -1
Color Space: 2
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full
Orbiter: Mode 2
Pioneer 111FD/151FD D75 Settings (ONLY use these settings after the 150 hour break-in period!!!!!!!!!)
Picture:
AV Selection: Sports
Contrast: 26
Brightness: +1
Color: +4
Tint: 0
Sharpness: -15
Pro Adjust
Pure Cinema
Film Mode: Off
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 2
Gamma: 1
Color Detail:
Color Temp: Manual
R High -3
G High 0
B High +14
R Low -4
G Low 0
B Low -1
CTI: Off
Color Management
R -1
Y +2
G -3
C -4
B 0
M +1
Color Space: 2
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full
Orbiter: Mode 2
post #56 of 5267
I guess Ill have to do soem hunting in D-Nice's Settings thread.
I would select PURE mode from the get go. Its closest to the D6500 standard without any other adjustments.
Also select Color space to 2 and set the color temperature to mid-low.
I'm sure you can just download the break in DVD and burn it so you don't have to wait for the disc to arrive by mail. I don't have the link of the top of my head, but someone I'm sure can post it for you.
Congrats on the new monitor. May I ask how you managed to hang it up on the brick wall? Anchors with precise drilling? I'm pretty sure those bricks don't align perfectly between the mounting holes for the wall mount.
post #57 of 5267
Are you in a pitch black room... Only there I can see them, but they are obvious there.
post #58 of 5267
Congratulations! Looks sweet, can't wait to see it in person. How high is the bottom of your 141 to the floor? Looks like my set up.
If you get a chance, I would love know what the mounting hole measurements are. I'm sure their are more pressing matters now but if you get a chance let me know.
post #59 of 5267
congrats and nice pics vancouver.
Is that a small sub sitting on the floor under the bottom left corner of the 141?
post #60 of 5267
Mounting hole measurements are
33 1/2 by 18 1/3 going of memory, its in the spec guide on the site.
27" from the floor
view distance is 10 feet.
