Originally Posted by
mariob33
The BUZZ seems to be louder depending on what is being watched... I picked it up from bestbuy magnolia, i think i will call them and explain the situation and get a new one.. I would hate to have to break in another set but..I would hate to wind up witha dud..
Do i need controlcal longterm to tweak the settings or is it once they unlock it im good?
No its not the default pure mode..The red picture is really bad when I introduce the Denon.. However, its lessened if i let the denon touch the picture.. In other words if I set say the output rez from denon to 1080p...
yes, return and swap it while you can from the bb/mht. no guarantee the next one will be less buzz but while your in the return period i would at least give it a shot.
the regular settings are available to the user at any time.
but once an owner using ControlCal or the calibrator using ControlCal accesses and sets up the ISFccc settings then they are locked and only accessed by using ControlCal again. so, yes if you want to access and tweak the ISFccc settings then you need a copy of ControlCal for your own use.
do you have a through setting on the Denon?
