AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Signature Elite 141 Owners Thread
Signature Elite 141 Owners Thread - Page 173
post #5161 of 5242
If your display got dammaged (one blown input), I'd strongly recommend you have it repaired now and covered by the insurance as well, if possible. Dammage could have occured in ways not yet visible, but that may show up over time. And the longer we wait for any repair, the higher the risk that parts may be difficult to obtain.
post #5162 of 5242
I appreciate the concern... this has not been an easy process.
post #5163 of 5242
I got a WDTV Live Plus media streamer and I have a choice in the video options for 8 or 16 bit.
I have an Elite Sig 101-FD.
Which is best for my set?
thx
bob
post #5164 of 5242
thx
bob
According to the WDTV Live Plus manual:
Note: 12 bit color is not compatible with all screens. If you select 12 bit color and your TV is not
compatible, display will be garbled. Wait 30 seconds and the media player will automatically default
back to 8 bit.
post #5165 of 5242
Originally Posted by Nickff View Post
Are those setting for deep color? If so, is anything that takes advantage of deep color yet? I would try both and see if there is a difference.
Yes, deep color setting, whatever that is? LOL
I didn't see a difference but was curious.
thx
bob
post #5166 of 5242
Assuming you mean 8 or 12 bit it doesn't matter. If your video chain will pass Deep Color 8 bit per pixel will show as 24bit on the info display and 12 bit per pixel will be displayed as 36bit.
16 bit per pixel is in the standard but the Kuro is documented as 8 or 12 only.
post #5167 of 5242
Sorry, 8 or 12 and it does show 24 or 36 bit. You are saying I won't see any difference in the PQ?
On another note, I have an output choice of 1080p 24,50, or 60 hz from the WD.
Which is best for my display? (m2ts, mkv files, streaming netflix)
thx
bob
post #5168 of 5242
Match the source (which should happen automatically). The display supports all of those framerates.
post #5169 of 5242
Originally Posted by bioman35 View Post
Is the Signature Elite series still being sold? If so, anyone know a reputable e-tailer selling?
Try the Pioneer Store in Orange County, CA.
post #5170 of 5242
1 more setting that I need help with:
"select color space (set to Auto, or RGB
High, RGB Low, or YCbCr)."
The manual offers no explanation.
thx
bob
post #5171 of 5242
If you use AUTO at each end the devices will attempt to negotiate a common setting. This can fail so some folks say don't use auto. Kuro monitors also fail using AUTO if the other end sets RGB-CE (low, 235 etc). Otherwise RGB High is RGB 0-255, RGB Low is RGB 16-235 and YCbCr is probably YUV422. If it's YUV444 instead it will be obvious.
post #5172 of 5242
I just checked and my 101 is set to auto on all the hdmi inputs.
Pic seems fine with both devices on auto but I am open to suggestions? What would you try next?
thx
bob
post #5173 of 5242
If you're happy what are you trying to fix?
post #5174 of 5242
Higher happiness, of course
Plus I'm a perfection seeking tweak
bob
edit: All kidding aside, I like to learn and always want to optimize my system just like you or anyone else.
post #5175 of 5242
D-Nice is on his way to calibrate. No clue what I am really getting into and hoping it is worth the money but regardless of that I am excited!
post #5176 of 5242
There is know way to know whether you will be happy. Some people like a picture that is not set according to the industry guidelines. My friend loves his 63" plasma with over-saturated colors and too much contrast. I would never try to talk him into an ISF calibration... he doesn't seek "correct".
I, only the other hand, will always have my main display calibrated. Now that I have seen the results, I am distracted when I watch other's displays.
post #5177 of 5242
I was skeptical about this...
...DeWayne came over and began the pretests. He stated he wasn't sure I would be able to notice much difference in the light. This made me more skeptical.
AMAZING! I had unlocked the isf's prior and even messed with the settings using a disc. The difference blew me away, even in the light. So excited and will always get my monitors calibrated from now on. The biggest skeptic, my wife, was sold too!
It was honestly like someone took a rag and wiped a very light film from the screen...everything was more clear, more pop, more dynamic...CRAZY!
post #5178 of 5242
Excellent. If you wouldn't mind (not that D-Nice needs more praise) posting your calibration report in htwait's report thread it helps everyone.
post #5179 of 5242
I would but I have no clue where to start. Any step by step directions?
post #5180 of 5242
Click HERE to go to the last page. Look at a couple of reviews and then post yours. You can just cut and paste the text from here or add something different.
Or you can PM htwaits and he'll repost your report for you.
post #5181 of 5242
I'll post a link to your report in the list that's linked at the bottom of my post.
Edit: Done.
post #5182 of 5242
I just received my pro 101fd today. I now have both the pro 101fd and the pro 111fd. I think im going to do a side by side comparison in a pitch black room to see how much blacker the 101 really is.
post #5183 of 5242
Nice
Where did you get it?
How much did it cost?
post #5184 of 5242
I got it from Walts TV for $2800. They're located in Arizona. It feels good being a part of the Signature family. These tvs are so hard to find!
post #5185 of 5242
Do they sell em online? I live in FL. Thinking about getting on if I can get it for a great price as you just did.
Anyone feel free to chime in!
post #5186 of 5242
Yeah they sell online. walts.com. I think I got the last one though..
post #5187 of 5242
Dam it! No luck for me! Thanks for the info though.
post #5188 of 5242
Wow! They have em in stock but no where near the price you've said!
post #5189 of 5242
Your very welcome. Yeah that is the original price. You have to call them. Ask for Miles. Hopefully he will give you a better price. Good luck!
post #5190 of 5242
In my searching, I think that I already know the answer to this, but has anyone discovered or devised any way to use a universal remote (an XSight ARRX18G, in this case) to select AV modes with any precision? I want to be able to select Game mode for when I am using my PS3, and an ISF mode for everything else. Since the XSight has no "state", I don't see a good way to do this.
I believe that I've seen some reference to setting things up with multiple HDMI inputs, which I'd rather not mess with. If only I'd gotten an AV receiver with 2 HDMI outs. I really don't like the idea of putting a switch in the mix, for fear of confusing, frustrating, and otherwise complicating things for my wife.
