I posted this on the 09FD thread, but applies here as well:
I still hear the herds of "lets go Digital, why use analog, HDMI all the way" debating this issue, when it is a very simple thing: At some point in the chain, there will be
a) Processing (decoding, application of Bass Management, effects, etc)
b) Digital-to-Analog conversion.
The important thing is WHO does it best, not WHERE it is done.
for example, using the 90FD as the transport vs, say a 84TSxi receiver, the obvious choice would be to use all the audio processing and DAC conversion on the 90FD, as it will be factors better than that found the receiver:
Conversely, if one where to use the 51FD as the transport, and pair it up to a high end receiver or Processor, such as the SC-09TX for example, the obvious choice would be to let the SC-09TX do all the processing, and DAC conversion:
and then of course, you got more complicated situations, in which sometimes it is better to do it in the transport, and sometimes in the processor. Take my example, for example: The Proceed AVP2+6 is, arguably, one of the best analog processors to date! Extremely accurate, transparent, and musical, with dual differential DACs per main channel, four "SHARC" 32-bit fixed/floating point processors, intelligent FIFO digital input buffers, etc, etc....basically a Mark levinson no.40 in a small package. However, it lacks the capability of handling newer HDR audio tracks. In this situation, given its musical prowess and magnificent DD and DTS decoding (with full THX Ultra2 Post Processing), it is best to let the AVP2 do all the CD and DVD processing and DAC (blue line: bitstreamed via Digicoax or Toslink). Conversely, you would want a capable transport to be able to do all the SACD/DVDA decoding, as well as all the new HDR audio processing, apply the necessary BM, and send it to the AVP2 for preamplification only, prior to going to the Amp stage:
there are other combinations thereof as well.....Again, the importance should be put on WHO does the best processing/DAC, not WHERE it is done.
-Sherv
-Sherv
