AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung Series 9 Owners - Observations, Comments and Advice
Samsung Series 9 Owners - Observations, Comments and Advice - Page 118
post #3511 of 3775
Originally Posted by squall12 View Post
hi guy,
need help what is the best setting for samsung 46inch A950 and i dont want to mess with service menu.
Using the TV for
PC - game and movie
PS3
Xbox360
Blueray
PS2
Wii
thanks
anyone have any good setting which using console and pc on this samsung A950 LCD TV?
post #3512 of 3775
From decades of observation, the A/C line supplying you home theater system has a major effort upon the sound and video quality. Note I’m NOT talking about anything remotely having to do with Monster or snake oil.
In addition the components themselves interact with each other in many ways. I always think of the human body with its many sub-systems which directly on indirectly effect each other.
From experience, the Samsung local diming LEDs consume power differently than traditional LCDs as the individual LEDs draw power from the A/C line in ferocious spurts switching in the nano-second range.
Conventional wisdom states the power supply should be designed to adequately power the displays lighting system. There is no debate here other than some third tier power supplies are prone to failure.
Is 60Hz too slow to provide instantaneous power? In my opinion it is for high performance applications.
My solution is to isolate the other components from the Samsung 950 and provide a local storage of instantaneous energy by using the Furman Power Factor Pro (PFP). This unique form of power conditioning raises the fidelity of my 950 higher than any other display. Note: I dedicate a PFP to supplying just the A950.
All aspects of the picture are refined especially at the pixel level: let’s call it micro-sharpness, micro-contrast and micro-color. Watching Sam Sheppard on Fox HD, I easily saw the three studio lights being reflected from his eye. That dear friends is the new level of discrimination for which the PFP indirectly allows.
Low level screens are just as impressively resolved as the brighter ones. Many ordinary scenes are just simply amazing.
True high fidelity for those willing to dare!
post #3513 of 3775
I just ordered the LN46A950 Anyone have the linkstick, is it worth getting? Any other accessories to buy?
post #3514 of 3775
anyone can share his/her best setting (beside going to the service menu which i dont want to do) for using on movie and games and i dont watch any sport...
thanks again.
post #3515 of 3775
hi guy,
please help me checked below serial no for 55inch A950 which my friend brought.
Serial no:AS1G3MJQC00004W - what is the firmware and manufacture date?
thanks
post #3516 of 3775
hi guy,
thanks
If that is the serial number on the right backside edge of the set & not the box then go register it on Samsungs website and it will show you the build date. The firmware you will find in the menu parameters. Im pretty sure you will have the latest firmware 1004.0
post #3517 of 3775
60Hz is the frequency of the electricity of the power line...Hz and demand have nothing in common...
All the FPF products are no more than power conditioners. The effect on your picture will be psychological not physical unless you have before/after tests that show color change or lumen change.
Same for sound quality of your stereo.
post #3518 of 3775
Hi Folks,
Haven't been here in a while (one of the original September 2008 owners).
Question: Did anyone get firmware updates from Samsung? Do they email it to you or do they have to send a tech out?
I am on the phone with them about blacks and an issue when in PC input w/o any signal - the tv just about freezes. They said they don't have any firmware updates.
They want to send a tech out. I'm not sure if that it best, but they said no other way...
Thoughts?
post #3519 of 3775
hi guy,
thanks
March 2009
post #3520 of 3775
Originally Posted by omeletpants View Post
March 2009
thanks
post #3521 of 3775
Hi all,
got my 55" yesterday, what a marvelous piece of tech!
LE-55A959D
post #3522 of 3775
Is that like a screen saver ? ...if so , how do you do it, somewhere in the menu ?
post #3523 of 3775
press Button "Content" on the remote, Choose "Gallery", then "Art", there you go.
post #3524 of 3775
Based on the feedback here and the fact BBY had this one for less than the 8000, I just bought it and installed it yesterday. It looks great. I bought a stand that swivels in case the off angle viewing was an issue, but so far I have left it facing center.
I ended up putting better blinds up in the room and ajacent rooms to reduce reflections and now I see none. With the blinds drawn I like the glossy screen.
The new stand and blinds killed my budget so I do not have the budget for a calibration and would love any settings anyone feels like sharing. ( I have not found a thresd on it here via the google search)
I have an old avia disk I will use in the BD player and game systems. Then I assume I just copy the settings for the DTV box input?
Thanks again for everyones feedback - I love this set.
P.S. I also get the "TV" input as an option, but since my satellite is on HDMI there are no channels active and I can't find a way to turn that off as an input option when changing inputs.
post #3525 of 3775
Bump.
Really? No interest in this?
Originally Posted by jdryyz View Post
These reports of possible bad caps being used in our sets has me concerned. The A750 model was mentioned, however. Is there any other indication that the A950 uses defective capacitors? I've had my set since February and have had no problems at all, but I know what bad capacitors can do to electronics. They are ticking time bombs.
If anyone here has cracked open their A950 for any reason, did you notice anything funny in this area? I wouldn't dare open my own, I'm just too clumsy.
The good news here is this particular problem can be easily substantiated by a physical inspection, if there are enough willing participants, that is.
post #3526 of 3775
what swivel stand did you get?
thanks
TVbc
post #3527 of 3775
I'm thinking of getting this set, but no one in my local area carries it on display. I need to know if my center channel speaker can be placed in front of the TV when the TV is on a pedestal. Can someone who has the TV do me a favor and measure from the bottom of the pedestal to the point where the picture begins, i.e., the top of the piece of plastic that frames the bottom of the screen? I'd really appreciate it.
post #3528 of 3775
To clarify, I am asking about the 55" version of the TV.
post #3529 of 3775
Minus the thickness of the stand it is 5 1/4" to the bottom of the screen.
If your speaker has to sit on the TV stand 4 3/4".
Actual TV stand dimensions are: 13" depth x 26" width.
If your in no hurry wait till BB puts the below stand back on sale. I got for 219.00 a month ago. It really does this 55A950 justice IMO.
http://www.bestbuy.com/site/olspage....=1165609791326
Gives you plenty of room for everything and is future-proof for a 65" LCD in the future if you desire.
post #3530 of 3775
The TV needs to go in a cabinet that's built in to the wall, and the center channel has to go in front of the TV -- there's no other way. What do you mean 5 1/4" "minus the thickness of the stand"? Is 5 1/4" the thickness from the tabletop that the TV is on to where the picture begins? That's what I'm trying to measure. Thanks.
post #3531 of 3775
Yes ! Bottom surface of the stand to where the screen starts is 5 1/4".
post #3532 of 3775
thanks again.
Here are my settings which are based off a set that was posted by HiFiFun awhile back after he calibrated the set. It looks like he has since removed his post otherwise I would just link you to that but these settings are the best I was ever able to find and I have used them since I purchased my 55" 950 back in March.
EDIT: HiFi's original settings are quoted here: http://www.avsforum.com/avs-vb/showt...3#post16083593
Pretty sure he posted an updated set with the 72 contrast and HDMI Black level set to Low but I'm not able to find that anywhere now.
Mode: Movie
Backlight: 5
Contrast: 72
Brightness: 45
Sharpness: 20
Color: 50
Tint (G/R): G50/R50
Detailed Settings
Black Adjust: Off
Dynamic Contrast: Off
Gamma: 0
Color Space
Red: R-42 G-5 B-8
Green: R-41 G-43 B-19
Blue: R-0 G-0 B-44
Yellow: R-37 G-35 B-0
Cyan: R-52 G-50 B-50
Magenta: R-40 G-5 B-40
White Balance
R-Offset: 23
G-Offset: 25
B-Offset: 22
R-Gain: 33
G-Gain: 22
B-Gain: 23
Flesh Tone: 0
Edge Enhancement: Off
xvYCC: Off
LED Motion Plus: Off (personal preference...everything is dimmer with this on)
Picture Options
Color Tone: Warm2
Size: 16:9 (personal preference)
Digital NR: Off
DNIe: Off (if available)
HDMI Black Level: Low
Film Mode: Auto1 (if available)
Blue Mode Only: Off
Auto Motion Plus 120hz: Low (or personal preference)
Smart LED: On
That should be everything. As I said before these were the best settings I was ever able to find as far as giving the set natural color reproduction and great black levels without losing detail (thanks again to HiFiFun for posting these awhile back).
post #3533 of 3775
Seriously man, unless you have some irreplaceable speaker, you might not want to be basing your tv purchase off of whether or not your speaker fits.
Buy a slimmer center channel?
I'd hate for anyone to pass over this tv because of 1/2 an inch clearance for a speaker that probably costs less than a tenth of this set.
I know I don't know the particulars of your situation, but there have got to be other options.
post #3534 of 3775
Mode: Movie
Backlight: 5
Contrast: 72
Brightness: 45
Sharpness: 20
Color: 50
Tint (G/R): G50/R50
Detailed Settings
Black Adjust: Off
Gamma: 0
Color Space
Red: R-42 G-5 B-8
Blue: R-0 G-0 B-44
White Balance
R-Offset: 23
G-Offset: 25
B-Offset: 22
R-Gain: 33
G-Gain: 22
B-Gain: 23
Flesh Tone: 0
xvYCC: Off
Picture Options
Color Tone: Warm2
Digital NR: Off
Blue Mode Only: Off
Smart LED: On
thanks for the setting but can it be used on 46inch version??
thanks
post #3535 of 3775
thanks
Yes they can. I had my 55a950 ISF-Calibrated and the certified tech used the movie mode to perform the cal and it is adjusted to 6500K. The backlight is actually set to 8 and the other settings are considerably different then the above to acheive a calibrated 6500K picture. Very natural and not to dull as normally this is the case after a pro-cal.
Bear in mind though with the variable build-dates of our sets and the fact that NO manufacturer uses precision rated components internally there can be as much as a +/- 3% difference between each unit. Using anyone elses settings can be a good baseline to start with & then just tweak yours in to your individual eye observations.
post #3536 of 3775
Originally Posted by leftovers View Post
for the 55" screen:
Front of glass bezel to front of glass base: 4.5"
from glass base to top of glass bezel 4 15/16"
from glass bezel to my stand (not tv's glass stand) is 5 1/4"
fyi
post #3537 of 3775
Originally Posted by TVbc View Post
not according to the ISF forum FAQ. no special run time required, only suggest wait until your initial return period is up so you don't waste money on pro calibration. if doing it yourself no wait period needed at all.
LEDs ? bulb temp? LEDs are not bulbs. and factories aren't doing this prior to shipment.
TVbc
LEDs are a type of bulb sure they aren't incandescent , fluorescent or HID but they are an electronic bulb. That diode does contain phosphors. They do and will change color over time(aka color temperature will shift) they are rated in either wave length or kelvin temperature or both depending on the diode manufacturer. The LEDs are tested and burned in at manufacturing time to ensure they are within the range required of the particular LED color being manufactured. They are then tested again at the LED tv manufacturers either in std QA spot part testing and/or set QA testing during manufacturing to maintain quality.
post #3538 of 3775
Just FYI, all the modes are inherently the same. Movie and dynamic are identical except that the factory has "preset" the settings differently. If you place the same settings on movie and dynamic you will get an identical picture.
post #3539 of 3775
Thanks & your right. Im aware of that from the calibrator but most certified techs that perform an ISF-Cal pick the movie mode to perform the Calibration on and lock in the settings by greying out & preventing the owner from changing them unless you go into the SM.
They also change the Mode name from Movie to " Calibration " and also give you two more modes named ISF-Day Mode & ISF-Night Mode. All three are tweaked a little different. Which is good if folks have alot of windows during the daylight hours.
post #3540 of 3775
LED`s simply put flucuates in light intensity from the amount of current variably driven thru them and their lifespan far exceeds that of any other light source utilized in LCD`s to date.
You can perform an ISF-Cal right-off the assembly line since their is no initial degradation or limiting factors of the diode.
Thats not saying that a single LED in the cluster on one of the dimming boards wont outright fail but by the time you ever notice any abnormalities of decreased light output you will be ready for another Television anyways !
Im waiting on the manufacturer that produces a set that will control in their processing algorithims EACH and every LED variably and not the whole cluster simultaneously on each dimming zone board. Then you will have the perfect LCD that has none of the issues we all complain about ! [Blooming, Halos, etc.]
