Originally Posted by Extra
I have a question, on your A950 sets, do the black letterbox bars in movies fade completely into black in a dark room?
On my set I could always tell the letterbox bars from the bezel in a dark room, though they are barely visible (this is with backlight on 6, movie mode, LED motion+ and LED on etc). However on a fade to black or a particularly black scene (such as the opening of Planet Earth) the black is completely black. Could any of you share some of your experiences?
Also, my TV has 1004 firmware.
Extra, I've owned 2 of these sets, one of the originals (which consequently had the dimming board issues) and my current one from a later production line (but not as recent as yours).
The first version, yes the bars completely disappeared, but that was because everything was ultra-dark. The side effect of this was that other scenes were also too dark. Their fix was a new dimming board and new code that didn't kill the backlights completely on scenes where there was at least a little bit of light. So now, yes I see the black bars, but they're very dim.
Also like you though, when the entire screen is black, it drops the black significantly.
You should also consider the zoning of the LED zones in this discussion as to whether or not your bars go completely black or not. Sometimes to me it looks as though some films are "skinnier" than others, and since the picture isn't really touching the top or bottom row of LED zones, those zones do stay off for the duration of the film.
Just watch the credits of a movie sometime. You should have complete darkness on the left and right sides of the screen. If not, decrease the contrast and brightness a until you achieve that total darkness, LED-off, look that you're shooting for.
