AVS › AVS Forum › Audio › DIY Speakers and Subs › My surrounds
My surrounds
post #1 of 3
How long do you think the foam surrounds on my Tumults will last, and I don't want to hear about your live forever rubber surrounds.
I've had em' about six years now.
Kg
post #2 of 3
Honestly, I couldn't give you a solid time frame that they might go out on you. It all depends on the environment that they are in and how you use em'. Since you have four Tumults, I can safely say that you aren't over driving them often. Or maybe you do... I dunno.
Modern foam surrounds are pretty robust nowadays. As long as they aren't in extreme conditions, they should last for years. The foam on my Tempest (the original) looks no different from the day I got it and it is about 6 years old. That and I have pounded the crap out of it too.
I'd say you are safe for at least another good 5-10 years. Guess that means the rubber surrounds on my RLp's should last til I die.
post #3 of 3
The biggest strain on foam is UV radiation and moisture, even those have been combatted heavily with modern treatments. Given that your subs look to be in a basement where these issues do not affect them, it is entirely possible for them to last 20 years.
