Originally Posted by
crutschow
18 AWG wire has a resistance of about 1.3 ohms per 100 feet (2-wire, round trip) so it depends upon the run length. 1.3 ohms reduces the sound level of an 8 ohm speaker by about 1.3dB.
If the speaker is exactly 8 Ohms at all frequencies, then there is no problem with a 1.3dB drop (just turn up the volume). The problem is that every speaker varies its impedance depending on frequency. The range may be roughly 4 Ohm to 16 Ohm over the audible frequency range. This means that the signal drop varies between 2.6dB [using crutschow's number] and 0.65dB (a 2dB difference) over the frequency range. This 2 dB difference means that certain frequencies are almost 1/2 as loud as other frequencies. The problem gets worse as the distance gets longer.
So, I guess it depends on how much the quality of sound matters to you.
crutschow
You might try Monoprice for the wire. They usually have good prices.
Mono will not likely have Plenum. Try a local electrical distributor in your area like Graybar or CED. I know we also sell to Lowe's who can special order this for you. You only need 16/2 wire. Don't ask for specific "speaker" wire - there really isn't a difference.
Hope this helps.
Carl
