Well, I'm about to start my basement's final subwoofer design and I might need a little bit of advice along the way with this one.
I've decided to go a slightly different way than two 12' or 15's.
I just ordered 12 of NHT's 10" subwoofers (new) that used to be used in their "SubTwo" boxes. My understanding is that they perform pretty good, so I figure why not overkill the whole thing and just use 10-12 to be on the safe side.
Xmax is stated at 12.5mm. I'm not really sure how these will compare with two 15's, but I guess it's too late anyway. One helpful member here said I should go with 12 to get the Ohms to work out right.....so I did.
Anyway, here are the specs: I have to be honest, I'm in the learning stage here, so I don't understand most of these numbers just yet.
Re: 9.58
Fs:21.5
Qms: 2.952
Qes: .444
Qts: .386
Vas: 103.84
Cms: .00561
Mms: 97.8
BL: 16.87
SPL: 85.47
Zmax: 73.2
Sd: .03631
Xmax: 12.5
Hg: 8
Hvc: 33
Photo of the old NHT SubTwo:
Their product sheet says:
Frequency Response:21Hz - 180Hz, +/-3dB
If anyone has any recommendations on box shape, or cubit ft per sub, it would be much appreciated. I have read that they should be in a sealed box, but I'm not sure of the size just yet. Power will be from an EP1500 or EP2500.
Xmax is stated at 12.5mm. I'm not really sure how these will compare with two 15's, but I guess it's too late anyway. One helpful member here said I should go with 12 to get the Ohms to work out right.....so I did.Anyway, here are the specs: I have to be honest, I'm in the learning stage here, so I don't understand most of these numbers just yet.
Re: 9.58
Fs:21.5
Qms: 2.952
Qes: .444
Qts: .386
Vas: 103.84
Cms: .00561
Mms: 97.8
BL: 16.87
SPL: 85.47
Zmax: 73.2
Sd: .03631
Xmax: 12.5
Hg: 8
Hvc: 33
