Okay, I spent awhile doing the testing. I did use my SPL meter on a tripod, but no computer program to run sweeps.
I put the Denon sub level at '4', not +12 max and turned all other speakers down to -12. I didn't turn on the sub, and measured all the other speakers at volume -20 on my Denon. They didn't register high enough to mess with the subs levels.
Turned on the sub amp (100 watts each) to a bit under half way and played the same 1 minute portion of a decent bassy song and set the SPL meter to find min/max for that 1 minute. Then I moved the sub to another position and started the song over.
I checked the max SPL for each location and noted which sounded best. Obviously these numbers aren't max SPL. Each done twice. Lots of positions yeilding about the same, but I'll just post the main ones.
Directly next to each side of the center channel firing out: 107db
Almost directly under sides of the screen firing out: 109db
Backed into the corners firing towards the middle: 109db
Corner straight out 4" away from walls: 109db.
Corner shooting up, down, other: 109db
BUT...
I tested these next two 3 times each because I was kinda surprised. Got the same number with each test.
In the corners 4" away from walls, but firing directly towards each other across the room: 110db
And then oddly enough, same 4" position, but firing directly at the front wall that the screen is on, looking at the back of the box: 111db.
Definitely sounded more bassy in those last 2 positions. But it wasn't as clean sounding as having the subs pretty much directly under the sides of the screen facing me. I think I would be happy with any of it along that front wall.
Does any of that mean much of anything? Louder in the corners, but possibly a bit more punch under the screen.
Just went and tried another possible position. 4" away from corners, facing side walls: 110db.
BUT...
