Originally Posted by
CreativeHT
Jason,
One other question - My throw distance would be just over 19ft (with 120" screen).
Do you think the HW10 would have the capability to create a bright enough picture when you take into account the throw distance being maxed out?
Any help would be greatly appreciated.
I'm not Jason (and I don't play him on TV either
), but using the ProjectorCentral calculator on the VW40 as a close approximation, and the lumens get quite low at the max screen size (117") provided in the calc for that model at that distance. Even accounting for an extra 10% brightness from the HW10, I think you might be hard pressed unless you use a HP screen (gain 2.0 or above). Though a 1.3 or 1.5 gain screen in a bat cave might work.
IMHO, YMMV, AFAIK, may cause dizziness, lethargy, and apathy,
shinksma
