AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Show me your COMPLETED Theater!
Show me your COMPLETED Theater! - Page 27
post #781 of 1046
Here's my theater room I just finished - well, I do have a few minor things to still work on but it's pretty much complete and I have been using it and loving it and have been waiting a long time to post it on this thread so here it is. Got some good pics with the lighting just right in a few, while a little dark in others but will try to get some better shots later when I consider it 100%, minus future upgrades of course! smile.gif Going to start a post construction thread soon for the Maddog Theater with other pics, specs, lessons learned, etc.
post #782 of 1046
Originally Posted by southkhaki19 View Post
Not sure if I ever posted an update image after I completed all the work. I still want to go a little larger on the screen. I am using an HD33 Optoma 1080p proj. I figured out if I pull the proj. back approx 8" and play with the zoom and open the lens a tad I can go from the current 131" to 148" fairly easily. It will just take convincing the wife that an extra 17" will be awesome! For those who want to ask but hate to ask, I don't mind discussing. I made an excel sheet and did a full calculation of everything in the room. My project came to approx 4500 without my gaming computer setup and 5400 with the gaming computer. This includes EVERYTHING down to the screws that I bought for the screen and the furniture, wires, projector, and even the bar I made from IKEA hackers site with the alcohol, & etc. I will say that I ran my own CAN lighting and wires, and everything else that required elbow grease. So if you are going to pay someone this may run into the hundreds, if not more.
Can i ask what color you used for the blue walls.... Very cool shade. Really awesome room.
post #783 of 1046
69glamboy,
Thanks! My walls are a flat Starless Night (BEHR Premium Plus Ultra) and yeah, I dig your color palette on your room! cool.gif
post #784 of 1046
We've sold our home and are in the process of tearing this down for the next theater, which should be completed in about 6 weeks.
post #785 of 1046
You are tearing that down?! Can't imagine what you will replace it with... It looks nice & seems to be setup nice for good sound. What are you plans for the new one?
post #786 of 1046
I think I can finally declare mine finished !
Cheers,
post #787 of 1046
All I can say is "Wow"!!! Looks incredible man
post #788 of 1046
post #789 of 1046
Cheers,
Peter: VERY NICE!! (but home theaters are never finished tongue.gif).
So what speakers did you end up with?
post #790 of 1046
The new one will be a bit wider (by about 1.75 feet) and (unfortunately) lower (current theater is 9 fee new one is 8), and using a different company to design it. Most important difference is that it will be on the 2nd floor so am having to do lots of things ti "try" to keep the sound contained.
post #791 of 1046
Hi Chuck,
Thanks ! I ended up getting the Procellas but it was a very close thing between them and the Seatons. In the end it came down to form factor more than anything else. The sound quality is amazingly similar and stunningly good !!
There's lots more photos in my thread (link in my sig).
I'm following your "No 4" with great interest. Are you off to CEDIA this year ?
Cheers,
post #792 of 1046
Cheers,
I'd love to go but we are in the middle of moving so I won't have time😒
post #793 of 1046
Originally Posted by mcascio View Post
After a lot of hard work, I'm glad I finally qualify to contribute to this thread.
See my build thread in my signature for additional photos and detailed photos during the build.
This is just SICK.
post #794 of 1046
Cheers,
I think your theater is awesome! Really digging the baffle ceiling! You have put thoughts into my head unfortunately for me lol. Great job! biggrin.gif
What is the size of your screen?
post #795 of 1046
It's 170" diag for 2.35, but the full screen is 3:1 and 17' wide.
Cheers
post #796 of 1046
That is big! Very nice! Why 3:1? I have never seen that aspect in any theaters before.
post #797 of 1046
Im guessing it has full masking capabilities and if you go with a 3.1, you will have a bigger 1.78 image compared if you went with 2.35/2.37. Your basically masking every input.
post #798 of 1046
I was thinking that the 16:9 image would be smaller from a CIH off of a 3:1 screen?
post #799 of 1046
Wouldn't 16x9 be smaller on a CIH 3:1? Four way masking on a 2:1 screen would give you similar image square footage between scope and 16x9, wouldn't it?
I am very curious as to why 3:1.
post #800 of 1046
It was all to do with LR speaker placement. The masking system has quite a large extruded aluminium frame and so if the masking frame was at 2.35 then the speakers would have to be some distance inside this to avoid diffraction problems. I think it worked out about 3m apart, but my room is 6.4m wide and this would have been too narrow for me. I use the room a lot for music and love a wide soundstage. The next option was to put the speakers outside the masking frame at 2.35 but this was too wide. So I decided to split the difference, put the speakers pretty much right on the edge of the 2.35 image and take the screen out to 3:1 and get the masking frame out of the way.
I'm very happy with the way it's turned out !
Cheers,
post #801 of 1046
My theater is about 2 weeks from being finished.
I need to wait for someone to post some pictures of a really bad theater before I post mine.
The last one is a hard one to follow.
post #802 of 1046
Just post it.
post #803 of 1046
Ok................................seriously................................this would be easy to follow for anyone! Time to post!!!! biggrin.gif
post #804 of 1046
Okay...............
I can definitely follow that theater system. LOL
I have a few details to finish up and then I'll get the camera gear out. More to come soon.
post #805 of 1046
post #806 of 1046
Hi,
my theater in living room ....
Edited by max-well - 9/24/13 at 1:16am
post #807 of 1046
Nice furniture!
post #808 of 1046
Old equipment ....
Yamaha rx-v 2700 reciever
Phillips bdp - 8000 bluray player
Dune hd1 media player
Bose acoustimass 10 seri IV
Panasonic pt-ae4000u
Panasonic pt-ae1000u
Panasonic pt-ae1000u screenshot
shot
Edited by max-well - 9/23/13 at 2:37pm
post #809 of 1046
OK, I think I'm pretty much done with my second build. It's a 2.35 setup in a 10' x 10' space.
post #810 of 1046
Awesome theater. Gives me some ideas for my spare bedroom.
