AVS › AVS Forum › Video Components › Home Theater Computers › ffdshow faq + mkv + dvd playback
post #1 of 7
All
I am confused about what I need. All I want to do is replay HD-DVD, blu-ray dvd, mkv, dvd folder rips.
What do I need ?
Do I need ffdshow ? If so, why, what does it do ?
Please help!
post #2 of 7
Originally Posted by mkedda View Post
All
What do I need ?
Please help!
Use ffdshow for DVD. The same for mkv if it isn't a rip of your BD/HD-DVD. For HD-DVD/DVD, just use software like PowerDVD.
post #3 of 7
why not just use powerdvd for dvds as well ?
post #4 of 7
honest question, i just dont understand why I need ffdshow in Vista 32bit. with Mkv all i need is haali media splitter and coreavc, right ?
blu-ray/hd-dvd will play in arcsoft, powerdvd, or windvd
regular dvd, dvd rips, same as above, right?
post #5 of 7
That if you need to use ffdshow (and MPC/ZoomPlayer) post-processing like deinterlacing or resizing. Else, just use PowerDVD if it suited you.
post #6 of 7
ah, ok. so if i need to adjust image size or resolution, i need an ffdshow.
post #7 of 7
No, it's not just about image size & resolution. It's the quality of image. If you're satisfied with PowerDVD then by all means use it. But the quality of Theatertek+ffdshow comepare to PowerDVD is night & day when you view with HDTV.
