I can't find it now... Anyway you're better off using WinDAS with a RS232 to TTL cable (use MAX232 IC) and fixing it the right way. WinDAS will allow you to change any parameters of the monitor, G2 voltage included.
Originally Posted by niqht
i have the over bright problem, the convergent/popping flyback (that doesn't pop anymore), and a super bright green retrace that auto turns off the monitor on cold start.
i've done the image restore, and didn't do much.
my main concern is the convergence. i adjusted the flyback through the vents and it helped some. the center of the screen is decent, but the outsides are spotty. ie, left bottom and top corners are great, 1/4 distance from center is noticeably fuzzy.
You mean, focus. These monitors are known for behaving like that, you can't get perfect focus on the whole screen. Though using Nokia Monitor Test will help.
Use Windows XP Mode for Windows 7 (free download from Microsoft).
I'm on the opposite side of a problem...
