Originally Posted by msherif
Hey guys, I have an onkyo TX-SR706, i was wrestling with my tv today, and was leaning on the subwoofer cable which is connected to the receiver, the y adapter, the pin borke, and the metal piece is stuck in the receiver. I cant connect my sub. I tired the other subwoofer connection, but didnt get any sound. If i were about to fix this, how much do you think its gonna cost? or is there any setting i need to change to the get the sub workin in the other port.
Any suggestion and advices are appriciated!
Thank you
Thank you
You need to find some way to extract the broken center pin from the sub jack. Try inserting a small screw to grab the inside of the tip and pull it out. The other sub jack is an input and does you no good.
Everything just worked. I imagine it got reset on a firmware update. Thanks!
If so, is there a way to repair this at home, avoiding ONKYO, or if not, is it worth it or should i buy a new receiver?
