Originally Posted by spartacus_33
OK... someone please give me some feedback here....
I've been running my 706 with Loudness Plus set to ON since Day 1.
I just bought a kick a$$ sub (Hsu VTF-3 MK3).
After reading the manual, it states that if you have the 706 set to Loudness Plus ON... THX+DynamicEQ is not available, even with THX listening mode selected. I'm going to play with this, but I have 3 questions:
1) Does THX+DynamicEQ make that much difference to you?
2) How are YOU running your 706 for movies (those of you with a sub or subs):
Loudness Plus ON
Loudness Plus OFF
3) I'm only running 5.1. Do I need 7.1 to be able to use DynamicEQ? I'm getting cross eyed reading the manual. If DEQ is available in 5.1... how do I turn it on and off? I've scrolled through the listening modes and don't see it?
Loudness Plus ON
Loudness Plus OFF
U should TURN OFF Loudness Plus, its not needed, Dynamic EQ proved to be much better, if u have Loudness Plus ON then Dynamic EQ is automaticlly disabled which is bad, They both do the same thing it was just tested and Dynamic EQ proved to be a much better feature, i forgot where i read it but it was in a professional review which i found on google.
Regarding CinemaFilter , i think they did take that feature out on the S706 LOL
im not sure why but i guess because it sucks
Music Optimizer is not present either right? (another crappy feature, it doesnt improve anything)
