AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › Sixaxis Control question
post #1 of 10
This will sound like a dumb question, but only because I'm a dumb person...
Do the new DualShock 3 controllers also have the sixaxis control built in?
I ask because, I personally don't like motion controlling (hence I stayed clear of the wii). Would I be able to play a game that has sixaxis controls built into it if I don't have a control that supports sixaxis?
Example: I saw the Folklore demo and it looked really cool until I realized you have to jerk the controls around to kill some enemies. Is there a way to opt out of this or is it foundationally built into the design of the game?
I hope I'm making sense...thx all!
post #2 of 10
The Dual Shock 3 has the tilt sensors. And its use in Folklore is neato burrito.
post #3 of 10
Yes they do!
The sixaxis was best used in MGS4 imo.
post #4 of 10
Thx for replying...
Do you know the answer to the second part of my question...is it "opt out-able"? I guess it's not a big deal, but I just want to chill out on my couch after a long day of work and not worry about waving my hands around and stuff.
post #5 of 10
Thx for replying...
yes most games the motnio sensors can be turned off
post #6 of 10
In -most- games it can be disabled. But not all, unfortunately.
I have forgotten, but what was the sixaxis used for in MGS4?
post #7 of 10
If done well, the motion controls are awesome, IMO. I love the way they use them in Ratchet & Clank.
post #8 of 10
No, you can't turn off the motion control of Folklore. However, it doesn't require much movement at all to absorb stuff... just flick your wrist gently and it'll work fine.
post #9 of 10
Ditto,
But I also don't like how they work in games like Motorstorm & tennis. Very happy I could turn it off with them.
post #10 of 10
Shaking the controller resets your camo. Not sure if it was used for anything else. I remembered back in the day they said you could control the MKII with it, but it never did that when I played.
  Back to Forum: PlayStation Area
