Originally Posted by
Huuuze
I own a Sharp LC42D64U. When watching standard definition TV (my provider is Dish Network), a small, thin band of "static" (for lack of a better term) appears at the top of the picture. This phenomena does not occur when watching HD programming.
Is this an issue with my TV or Dish Network? In either case, is there a known fix?
I have the same problem I believe. It's not your tv, it's the show/commercial. I get that once in a while on SD channels and during some commercial that are not in HD on the HD channels. The only way to fix is either Stretch the Image, or I think you might have an option in your Dish Receiver to move the picture. Kinda like on a pc monitor, you can move the picture up down left right, I think you can do the same with your Dish Receiver. But, move it too high and you might get a missing line on the bottom. It's a work around...not the best solution, but hopefully one day SD programming will get their act together.
