Hey everyone,
What I am looking for:
A DVD Recorder with a digital tuner built in, can output cable tv to the TV via component OR HDMI, and is cheap!
I'd appreciate any recommendations that fit those requirements.
I plan to use the DVD Recorder to record tv shows (obviously), and mostly to send cable tv to my TV via hdmi or component for use as PIP.
I have a Vizio VO42 HDTV. I am wanting to add a digital tuner so that I can watch, for example, a football game in HD via the Vizio's tuner, and have PIP of another football game coming from the tuner in the DVD Recorder. The Vizio's PIP will only let certain inputs be PIP with certain other inputs. HDMI with any non-HDMI input. Composite and TV Tuner only with a digital input. Thus, I can't just use a VCR to get another cable channel on the pip.
Thanks for you help!
PS- I looked at some at walmart and they seem alright, but if there is something cheaper or better for similar price, I'd go with it!
It's pretty much the default recommendation these days, not so much for being a great product, but simply being the only thing you can readily find on a shelf these days?
I just picked up a Panasonic DMR-EA18 because it records to DL disc but, when I read the manual it says it only records widescreen 16:9 on RAM disc
The link for redtag store says the Philips will record to DVD+DL.
