I have, in the past, used projector lamps that are of a slightly higher wattage than my original. Which is perfectly fine, as long as your projector's lamp wattage meets the nominal wattage required by the lamp to ignite.
However, i have never tried such a thing with different lamp types. I bought a new projector and i have a few 200w uhp lamps laying around, the new projector takes 200w p-vip lamps.
Now, they are both rated at the same wattage, luminosity, and efficiency, therefore they should both output the same heat.
Now, considering that, is there any foreseeable problem by trying to use a uhp lamp instead of the factory p-vip (metal halide lamp)?
