Originally Posted by
jrwhite
I believe all of the D6 and D7 panels are inorganic.
Jonathan
According to Ekkehart (
Cine4Home), there are organic and inorganic versions of both D6 and D7 panels. Only the C2Fine panels are exclusively inorganic.
NOTE: Most of the D6 panels are organic, and most of the D7 panels are inorganic. But neither is exclusive. The development of inorganic LCD panels was started while the D6 panels were still in production.
If a manufacturer states that their panels are inorganic, they could be either D6's or D7s, and the contrast ratio might be the only clue (unless the manufacture is more specific). If they say they are using the C2Fine panels then the panels are D7 & inorganic only, if I remember Ekkehart's post correctly (I can't find his post right now).
PS -- If I'm guessing
correctly, the 6100 will be the replacement for the 1080 and the 6500UB will replace the 1080UB models.
