AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung LN52A650 - calibration...please!
Samsung LN52A650 - calibration...please! - Page 2
post #31 of 40
Originally Posted by slumpey326 View Post
120hz can never be turned off. The tv is always running 120hz. AMP is just a special setting.
AMP is like 120hz on steriods, lol. I think AMP only should be used on any CG animation movie. You will be amazed by how the picture look on a animation movie with AMP on.
post #32 of 40
What's the best way to get rid of the "soap opera" effect that is seen on some shows and DVD's?
post #33 of 40
Originally Posted by Chevy-SS View Post
What's the best way to get rid of the "soap opera" effect that is seen on some shows and DVD's? -
Turn AMP off is the best way to get rid of soap opera effect.
post #34 of 40
brief, and straight to the point.
post #35 of 40
Thanks, I tried that last week. It helped a little, no doubt. Still got some of that live feed look though.
post #36 of 40
If it continue to be a problem then I suggest you to reset your TV to default factory setting. To do this -
Factory Reset
1. Turn off the TV
2. Press 'Mute' '1' '8' '2' 'Power'
3. The TV will start and you will be in the SM (give it a few extra seconds).
4. Select Optionbyte
5. Select Factory Reset twice
After factory reset make sure you go to the picture setting and turn your AMP off. It should turn all judder by auto motion processor to off.
post #37 of 40
Factory Reset
1. Turn off the TV
has anyone ever tried this factory reset in service menu and if so does it mess up what settings should look like.
post #38 of 40
No, it will not mess up your TV. It will reset all of your setting to factory default. You will only need to adjust your picture setting again because your old setting will be erased to default. After you reset your TV then why not try my picture setting and see if you like it much better.
post #39 of 40
factory reset, may try this
post #40 of 40
anyone know how to turn on the red light on the bottom?
