UPDATE: I'm "a bit" late in bothering to update this OP, but I figured I'd better provide the most important info we gained from the thread right in the first post, for any new readers.
Screenshot comparison #1 - Both USA versions - AVC vs MPEG-2 vs MPEG-2 PiP
Screenshot comparison #2 - Both USA versions - AVC vs MPEG-2 vs MPEG-2 PiP
Screenshot comparison #3 - Both USA versions - AVC vs MPEG-2 vs MPEG-2 PiP vs HD deleted scene
If you want to pick up the seemingly discontinued American AVC version, your best bet is to go to a brick & mortar store and look for the case type - and more importantly - the catalog sticker pictured at left:
AVC case + sticker ......................| MPEG-2 case + sticker
Screenshot comparison #4 - USA version AVC vs Australia release (stylized colors)
The recommended release is the Australian Blu-ray.
Other releases that may or may not be similar and may not be Region ABC:
(...Full unaltered OP text below...)
Lionsgate's Blu-ray of The Descent is supposed to have 3 different versions of the movie on the disc:
Unrated - AVC - seamless branching
Rated - AVC - seamless branching
Picture-in-Picture - MPEG-2 - separate encode
BUT there are also discs out there that instead have the Unrated/Rated movie encoded as MPEG-2! The different presentations have caused some confusion with people thinking others were just watching the wrong encode and complaining for no reason.
In March, jorange posted about this in the Blu-ray Players forum and was swiftly ignored.
In July, lgans316 noted this in a thread about a separate issue, and has been a bit more vocal about it.
In that thread, lescarphe said his PowerDVD codec display showed the same thing, as did saginawjuggalo and FoxyMulder with their PS3s. Shortly afterwards, Coxwell reported the same thing in the PQ Tier thread. Meanwhile other users thought these guys were insane as their own displays showed they were watching AVC encodes.
As I now have lgans316's MPEG-2 disc in my Blu-ray drive I can confirm without a doubt that this disc contains an actual MPEG-2 encode different from the AVC encode on other pressings. As proof, here are the massive specs listings for each version. (note that the audio is actually 6.1 discrete channels, but encoded as 7.1 LPCM)
AVC version (specs courtesy of Phloyd using BDInfo v0.3.1):
MPEG-2 version (specs using BDInfo v0.4.1):
Differences:
Disc size: AVC: 48,362,529,368 bytes | MPEG-2: 48,424,650,234 bytes
Unrated movie size: AVC: 23,020,302,336 bytes | MPEG-2: 22,999,492,608 bytes
Unrated total/video bitrates: AVC: 30.74/21.56 Mbps | MPEG-2: 30.71/21.53 Mbps
Rated movie size: AVC: 22,579,138,560 bytes | MPEG-2: 22,576,723,968 bytes
The Rated versions' bitrates happen to be practically identical, but are actually different at kbps precision. And of course, the PiP encode stats are identical on both versions (which proves they are being measured the same way).
In case anyone's still thinking this is a "flagging" issue on the MPEG-2 disc regardless of the number differences, the video is definitely decoded by MPEG-2 filters on a PC. AVC filters refuse to accept the output of Haali's video splitter for these files.
For the MPEG-2 version, "modified" dates range from 11/18/2006 to 01/08/2007, with some dates in between. The PiP was modified 11/18/2006. The 3 seamlessly branched files were modified 01/08/2007.
MPEG-2/Unrated graphs (Rated version is basically the same):
MPEG-2/PiP graphs:
Can anyone with the AVC version and a BD drive please post the "modified" dates/graphs? How about a PIX comparison? MPEG-2 vs AVC: same studio, same master, same bitrate. Could be interesting. I noticed some pulsating in static shots on the MPEG-2, possibly blocking elsewhere. I wonder if this is alleviated in the AVC.
Conclusions:
- PS3 and PowerDVD always display the codecs correctly, regardless of firmware
- Lionsgate encoded, authored, and pressed one version of this disc (probably MPEG-2) and then for some reason decided to re-encode and replace just the main movie, re-authoring and re-pressing with the rest of the disc structure kept seemingly identical
- The unannounced MPEG-2 version somehow made its way into retailers' stock, including Amazon and Movietyme
There is also a July 2007 High Def Digest forum post claiming the same thing of Lionsgate's Young Guns release.
Is it possible to tell which version you have from the disc or package markings? I don't think the other thread quite nailed that down.
- Netherlands: 2009-07-09
- Germany: 2009-10-09
- United Kingdom: 2009-11-09
Code:
Total Video
Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track Secondary Audio Track
The Descent: Original Unrated Cut (seamless branching) AVC 1:39:50 23,020,302,336 48,362,529,368 30.74 21.56 LPCM 7.1 6144Kbps (48kHz/16-bit) DD AC3 5.1-EX 640Kbps
PLAYLIST REPORT:
Length: 1:39:50 (h:m:s)
Total Bitrate: 30.74 Mbps
Description:
FILES:
Name Size Length Time In Time Out
00002.M2TS 21,667,233,792 1:33:55.254 0:00:00.000 1:33:55.254
00024.M2TS 1,353,068,544 0:05:55.730 1:33:55.254 1:39:50.984
VIDEO:
Codec Bitrate Description
MPEG-4 AVC Video 21559 kbps 1080p / 23.976fps
AUDIO:
Codec Language Bitrate Description
LPCM Audio English 6144 kbps 7.1 / 48kHz / 16-bit / 6144kbps
Dolby Digital EX Audio English 640 kbps 5.1-EX / 48kHz / 640kbps
Dolby Digital Audio English 192 kbps 2.0 / 48kHz / 192kbps
SUBTITLES:
Presentation Graphics English 18 kbps
Presentation Graphics Spanish 17 kbps
CHAPTERS:
Number Time Name
1 0:00:00.000 Chapter 1
2 0:08:10.031 Chapter 2
3 0:14:22.111 Chapter 3
4 0:21:33.625 Chapter 4
5 0:28:50.270 Chapter 5
6 0:39:38.959 Chapter 6
7 0:45:24.012 Chapter 7
8 0:54:25.011 Chapter 8
9 0:58:23.249 Chapter 9
10 1:05:17.330 Chapter 10
11 1:10:16.086 Chapter 11
12 1:16:57.654 Chapter 12
13 1:20:17.979 Chapter 13
14 1:25:00.970 Chapter 14
15 1:29:05.465 Chapter 15
16 1:31:46.459 Chapter 16
17 1:39:50.734 Chapter 17
Code:
Total Video
The Descent: Rated (seamless branching) AVC 1:38:35 22,579,138,560 48,362,529,368 30.53 21.36 LPCM 7.1 6144Kbps (48kHz/16-bit) DD AC3 5.1-EX 640Kbps
PLAYLIST REPORT:
Length: 1:38:35 (h:m:s)
Total Bitrate: 30.53 Mbps
Description:
FILES:
00025.M2TS 911,904,768 0:04:40.655 1:33:55.254 1:38:35.909
VIDEO:
MPEG-4 AVC Video 21360 kbps 1080p / 23.976fps
AUDIO:
SUBTITLES:
Presentation Graphics Spanish 18 kbps
CHAPTERS:
Number Time Name
17 1:38:35.659 Chapter 17
Code:
Total Video
The Descent PiP Secondary Encode MPEG-2 1:39:50 12,668,018,688 48,362,529,368 16.92 15.91 DD AC3 2.0 224Kbps
PLAYLIST REPORT:
Total Bitrate: 16.92 Mbps
Description:
FILES:
00020.M2TS 12,668,018,688 1:39:50.985 0:00:00.000 1:39:50.985
VIDEO:
MPEG-2 Video 15911 kbps 1080p / 23.976fps
AUDIO:
Dolby Digital Audio English 224 kbps 2.0 / 48kHz / 224kbps
CHAPTERS:
Number Time Name
Code:
Total Video
The Descent: Original Unrated Cut (seamless branching) MPEG-2 1:39:50 22,999,492,608 48,424,650,234 30.71 21.53 LPCM 7.1 6144Kbps (48kHz/16-bit) DD AC3 5.1-EX 640Kbps
DISC INFO:
Disc Title: LOGICAL_VOLUME_ID
Disc Size: 48,424,650,234 bytes
Protection: AACS
BD-Java: Yes
PLAYLIST REPORT:
Total Bitrate: 30.71 Mbps
Description:
FILES:
00002.M2TS 21,593,690,112 1:33:55.254 0:00:00.000 1:33:55.254
00024.M2TS 1,405,802,496 0:05:55.730 1:33:55.254 1:39:50.984
VIDEO:
MPEG-2 Video 21532 kbps 1080p / 23.976fps / 16:9
AUDIO:
SUBTITLES:
Presentation Graphics English 18.263 kbps
Presentation Graphics Spanish 17.353 kbps
CHAPTERS:
Number Time Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time
1 0:00:00.000 0:08:10.031 23,295 kbps 39,739 kbps 00:02:28.148 35,123 kbps 00:02:24.144 33,799 kbps 00:02:31.443 121,449 bytes 689,370 bytes 00:00:00.584
2 0:08:10.031 0:06:12.080 21,075 kbps 36,640 kbps 00:08:10.031 33,533 kbps 00:08:10.031 30,516 kbps 00:08:10.031 109,874 bytes 689,371 bytes 00:09:27.650
3 0:14:22.111 0:07:11.515 23,397 kbps 38,819 kbps 00:15:17.458 29,291 kbps 00:20:30.396 27,909 kbps 00:20:58.299 121,981 bytes 689,370 bytes 00:15:39.522
4 0:21:33.626 0:07:16.644 20,100 kbps 33,294 kbps 00:21:51.602 27,324 kbps 00:21:47.598 26,268 kbps 00:22:07.368 104,795 bytes 689,369 bytes 00:22:24.426
5 0:28:50.270 0:10:48.690 20,076 kbps 36,757 kbps 00:31:45.070 28,286 kbps 00:34:53.258 27,061 kbps 00:34:50.880 104,668 bytes 689,371 bytes 00:35:15.196
6 0:39:38.960 0:05:45.053 19,817 kbps 29,587 kbps 00:41:30.863 24,042 kbps 00:44:36.090 22,797 kbps 00:44:30.960 103,316 bytes 689,369 bytes 00:39:39.002
7 0:45:24.013 0:09:00.999 21,199 kbps 37,283 kbps 00:48:44.338 27,196 kbps 00:51:43.475 26,097 kbps 00:51:38.470 110,524 bytes 685,169 bytes 00:53:24.660
8 0:54:25.012 0:03:58.238 23,239 kbps 37,468 kbps 00:57:38.330 31,822 kbps 00:57:34.326 29,463 kbps 00:56:22.796 121,156 bytes 686,832 bytes 00:58:13.824
9 0:58:23.250 0:06:54.080 21,099 kbps 33,544 kbps 01:04:42.712 28,440 kbps 01:04:59.479 26,444 kbps 01:03:11.913 109,998 bytes 689,369 bytes 01:03:58.168
10 1:05:17.330 0:04:58.757 20,048 kbps 31,265 kbps 01:07:27.043 24,050 kbps 01:08:01.744 23,293 kbps 01:10:06.077 104,523 bytes 689,373 bytes 01:08:01.786
11 1:10:16.087 0:06:41.568 21,574 kbps 35,815 kbps 01:11:28.367 29,787 kbps 01:11:26.324 28,683 kbps 01:11:19.275 112,477 bytes 689,369 bytes 01:13:40.875
12 1:16:57.655 0:03:20.325 22,193 kbps 37,985 kbps 01:17:25.057 30,194 kbps 01:18:59.777 27,856 kbps 01:18:33.375 115,702 bytes 689,376 bytes 01:19:52.997
13 1:20:17.980 0:04:42.991 20,621 kbps 30,957 kbps 01:24:23.183 24,618 kbps 01:24:20.097 23,909 kbps 01:24:14.841 107,508 bytes 689,369 bytes 01:21:03.442
14 1:25:00.971 0:04:04.494 23,474 kbps 38,129 kbps 01:28:47.489 30,387 kbps 01:28:25.425 28,457 kbps 01:28:21.087 122,384 bytes 689,370 bytes 01:25:44.097
15 1:29:05.465 0:02:40.994 21,777 kbps 36,642 kbps 01:29:53.179 29,725 kbps 01:29:49.759 27,185 kbps 01:29:48.883 113,537 bytes 689,369 bytes 01:31:32.320
16 1:31:46.459 0:08:04.526 22,878 kbps 36,464 kbps 01:31:47.043 29,985 kbps 01:31:50.380 29,209 kbps 01:31:46.584 119,276 bytes 689,374 bytes 01:32:12.110
STREAM DIAGNOSTICS:
File PID Type Codec Lang. Code Lang. Name Seconds Bytes Packets Bitrate
00002.M2TS 4113 (0x1011) 0x02 MPEG-2 5635.25 15,127,297,739 82,292,300 21,475
00002.M2TS 4352 (0x1100) 0x81 AC3-EX eng English 5635.25 450,821,120 2,641,530 640
00002.M2TS 4353 (0x1101) 0x80 LPCM eng English 5635.25 4,327,875,840 23,668,071 6,144
00002.M2TS 4354 (0x1102) 0x81 AC3 eng English 5635.25 135,246,336 880,510 192
00002.M2TS 4355 (0x1103) 0x81 AC3 eng English 5635.25 135,246,336 880,510 192
00002.M2TS 4356 (0x1104) 0x81 AC3 eng English 5635.25 135,246,336 880,510 192
00002.M2TS 4357 (0x1105) 0x81 AC3 eng English 5635.25 135,246,336 880,510 192
00002.M2TS 4608 (0x1200) 0x90 PGS eng English 5635.25 13,669,441 79,055 19
00002.M2TS 4609 (0x1201) 0x90 PGS spa Spanish 5635.25 12,989,975 75,327 18
00024.M2TS 4113 (0x1011) 0x02 MPEG-2 355.73 997,602,770 5,426,711 22,435
00024.M2TS 4352 (0x1100) 0x81 AC3-EX eng English 355.73 28,459,520 166,755 640
00024.M2TS 4353 (0x1101) 0x80 LPCM eng English 355.73 273,204,480 1,494,087 6,144
00024.M2TS 4354 (0x1102) 0x81 AC3 eng English 355.73 8,537,856 55,585 192
00024.M2TS 4355 (0x1103) 0x81 AC3 eng English 355.73 8,537,856 55,585 192
00024.M2TS 4356 (0x1104) 0x81 AC3 eng English 355.73 8,537,856 55,585 192
00024.M2TS 4357 (0x1105) 0x81 AC3 eng English 355.73 8,537,856 55,585 192
00024.M2TS 4608 (0x1200) 0x90 PGS eng English 355.73 6,941 44 0
00024.M2TS 4609 (0x1201) 0x90 PGS spa Spanish 355.73 5,147 34 0
Code:
Total Video
The Descent: Rated (seamless branching) MPEG-2 1:38:35 22,576,723,968 48,424,650,234 30.53 21.36 LPCM 7.1 6144Kbps (48kHz/16-bit) DD AC3 5.1-EX 640Kbps
DISC INFO:
Protection: AACS
BD-Java: Yes
PLAYLIST REPORT:
Description:
FILES:
00025.M2TS 983,033,856 0:04:40.655 1:33:55.254 1:38:35.909
VIDEO:
MPEG-2 Video 21357 kbps 1080p / 23.976fps / 16:9
AUDIO:
SUBTITLES:
Presentation Graphics English 18.485 kbps
Presentation Graphics Spanish 17.566 kbps
CHAPTERS:
16 1:31:46.459 0:06:49.451 20,607 kbps 36,464 kbps 01:31:47.043 29,985 kbps 01:31:50.380 29,209 kbps 01:31:46.584 107,434 bytes 689,374 bytes 01:32:12.110
STREAM DIAGNOSTICS:
00025.M2TS 4113 (0x1011) 0x02 MPEG-2 280.66 666,246,684 3,624,797 18,991
00025.M2TS 4352 (0x1100) 0x81 AC3-EX eng English 280.66 22,453,760 131,565 640
00025.M2TS 4353 (0x1101) 0x80 LPCM eng English 280.66 215,546,880 1,178,772 6,144
00025.M2TS 4354 (0x1102) 0x81 AC3 eng English 280.66 6,736,128 43,855 192
00025.M2TS 4355 (0x1103) 0x81 AC3 eng English 280.66 6,736,128 43,855 192
00025.M2TS 4356 (0x1104) 0x81 AC3 eng English 280.66 6,736,128 43,855 192
00025.M2TS 4357 (0x1105) 0x81 AC3 eng English 280.66 6,736,128 43,855 192
00025.M2TS 4608 (0x1200) 0x90 PGS eng English 280.66 0 0 0
00025.M2TS 4609 (0x1201) 0x90 PGS spa Spanish 280.66 0 0 0
Code:
Total Video
The Descent PiP Secondary Encode MPEG-2 1:39:50 12,668,018,688 48,424,650,234 16.92 15.91 DD AC3 2.0 224Kbps
DISC INFO:
Protection: AACS
BD-Java: Yes
PLAYLIST REPORT:
Description:
FILES:
VIDEO:
MPEG-2 Video 15911 kbps 1080p / 23.976fps / 16:9
AUDIO:
CHAPTERS:
1 0:00:00.000 0:08:10.031 17,247 kbps 35,172 kbps 00:01:43.520 28,529 kbps 00:01:47.774 27,917 kbps 00:01:42.561 89,917 bytes 528,319 bytes 00:07:03.506
2 0:08:10.031 0:06:12.080 15,525 kbps 30,066 kbps 00:08:10.031 25,726 kbps 00:08:10.031 22,859 kbps 00:08:10.031 80,943 bytes 562,482 bytes 00:08:37.100
3 0:14:22.111 0:07:11.515 17,133 kbps 27,212 kbps 00:15:17.458 21,975 kbps 00:20:30.396 21,027 kbps 00:20:58.174 89,322 bytes 563,850 bytes 00:16:22.064
4 0:21:33.626 0:07:16.644 15,123 kbps 27,276 kbps 00:21:51.602 21,670 kbps 00:21:47.681 20,190 kbps 00:22:07.117 78,843 bytes 555,952 bytes 00:23:42.630
5 0:28:50.270 0:10:48.690 15,295 kbps 34,388 kbps 00:38:30.308 23,660 kbps 00:34:55.885 21,745 kbps 00:34:50.880 79,742 bytes 514,214 bytes 00:37:20.947
6 0:39:38.960 0:05:45.053 15,068 kbps 22,730 kbps 00:44:38.718 18,531 kbps 00:42:06.566 17,264 kbps 00:42:06.065 78,559 bytes 559,350 bytes 00:44:28.374
7 0:45:24.013 0:09:00.999 15,744 kbps 26,741 kbps 00:50:50.589 19,416 kbps 00:50:50.506 18,646 kbps 00:49:37.850 82,082 bytes 551,495 bytes 00:50:50.631
8 0:54:25.012 0:03:58.238 17,091 kbps 31,379 kbps 00:56:23.005 23,532 kbps 00:56:20.794 20,782 kbps 00:56:36.184 89,105 bytes 544,113 bytes 00:56:20.836
9 0:58:23.250 0:06:54.080 15,463 kbps 25,334 kbps 00:59:27.731 20,363 kbps 00:59:19.723 19,917 kbps 00:59:15.093 80,619 bytes 549,934 bytes 01:00:33.588
10 1:05:17.330 0:04:58.757 14,680 kbps 21,254 kbps 01:10:15.086 17,620 kbps 01:10:10.998 17,384 kbps 01:10:05.993 76,536 bytes 380,200 bytes 01:10:15.920
11 1:10:16.087 0:06:41.568 16,141 kbps 30,454 kbps 01:11:25.948 23,117 kbps 01:11:25.990 22,117 kbps 01:11:19.442 84,149 bytes 499,206 bytes 01:13:38.247
12 1:16:57.655 0:03:20.325 17,012 kbps 28,456 kbps 01:17:25.057 23,153 kbps 01:18:36.503 21,752 kbps 01:18:33.375 88,693 bytes 434,039 bytes 01:17:25.850
13 1:20:17.980 0:04:42.991 14,967 kbps 22,240 kbps 01:24:00.827 18,332 kbps 01:23:19.453 18,123 kbps 01:23:20.495 78,032 bytes 499,809 bytes 01:20:18.022
14 1:25:00.971 0:04:04.494 17,725 kbps 32,717 kbps 01:28:45.987 23,979 kbps 01:28:25.425 22,402 kbps 01:28:39.064 92,409 bytes 529,968 bytes 01:27:55.729
15 1:29:05.465 0:02:40.994 15,656 kbps 25,326 kbps 01:29:49.801 19,968 kbps 01:29:49.801 18,356 kbps 01:29:48.925 81,623 bytes 566,960 bytes 01:31:46.501
16 1:31:46.459 0:08:04.526 15,732 kbps 31,909 kbps 01:31:46.793 24,085 kbps 01:31:46.501 22,516 kbps 01:31:46.501 82,022 bytes 574,028 bytes 01:33:33.942
STREAM DIAGNOSTICS:
00020.M2TS 4113 (0x1011) 0x02 MPEG-2 5990.99 11,915,640,981 64,842,463 15,911
00020.M2TS 4352 (0x1100) 0x81 AC3 eng English 5990.99 167,748,224 936,095 224
MPEG-2/PiP graphs:
Conclusions:
![The Descent (Original Unrated Cut) [Blu-ray]](http://cdn.avsforum.com/e/e4/50x50px-ZC-e4d4ec8a_B000JJ5F0W-51clVL2uVtL.jpeg)
I just got a new copy from Amazon last month and it was MPEG2.
