Originally Posted by
jerryknite
Does anybody have any suggestions for eliminating the small white line, I guess its called the VBI, thats only visible on a couple of channels?
yes, if youre comfortable opening the tv's case....in most older tv models u will find a VERTICAL SIZE and maybe even a VERTICAL POSITION control somewhere on the circuit boards...look for a glued-on paper label on the inside of the case cover that may show the locations....
while watching a channel with visible VBI lines tweak these controls just a touch to move the VBI lines up and out of sight....while youre in there do a touch-up of the FOCUS control....and the grey scale adjustments, if u know what they are....
be careful tho, there are high voltages present...u probably wont die but u could easily short out something and kill the tv if youre not careful.....use plastic tipped tools when youre near the circuit boards, if u have them....
