AVS › AVS Forum › Audio › Speakers › DEF TECH PM1000's and SANUS SF30 SPEAKER STANDS
post #1 of 2
Ok not sure if this is the place for this, and its is a last resort for me.
I have looked all over and I cannot find a "definitive" answer (pun intended) to the question I have.
I am looking for speaker stands for a pair of Definitive Technology ProMonitor 1000's. I have looked at tons of stands, and the SANUS SF30 speaker stands are the nicest that have caught my eye by far.
My question is this. In some of the descriptions I have found online, they claim there is a foundation mount system that allows you to actually mount the speaker to the stands base with some included screws(w/ the stand).
My def tech pm1000's have a screw hole in the Bottom Center of the enclosure... but I can NOT find ANYWHERE that specifies WHERE the HOLE on the stands upper base are and if there is ONE or TWO holes.
Point being.. ONE center hole with suit me PERFECTLY and I would buy these damned things NOW.
Has ANYONE used these before, or have any similar stands or better suggestions for use with the Def Tech PM1000's?
post #2 of 2
NEVERMIND
I FOUND the answer i was looking for.
  Back to Forum: Speakers
