AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Plasmas dimmer than LCD's?
post #1 of 13
I just went to Best Buy today and I noticed that The Panasonic TH-42PZ80U plasma was A LOT dimmer than the Samsung LN40a550 LCD. I know the bright lights in the store contribute to this, and the fact that they push the brightness up on the LCD's in store, but it was really noticeable and it just didn't have the same "pop" effect that the Sammy did. Is it really that drastic of a difference when the Plasma is in your room? Because I really like the bright vivid picture of the LCD compared to the dimmer plasma.
post #2 of 13
The big question is if you will like this bright light late at night in a room with no or very dim lights?
post #3 of 13
Yes in general it's normal that LCD's are brighter than plasmas, which will give it more pop when you see them next to each other. But brighter doesn't mean better or clearer or more pop, especially when they're not side to side to compare. It depends on how much light is in the room you're going to put the TV in. Normally the first thing people do is turn the backlight of an LCD down to about half because it's way too overblown in a home environment. For instance, I have an LCD and my backlight out of 10, is set to 3. It's not a very natural picture to have your TV so bright. However, if that's the way you like the picture, then yes it will be just as bright, if not brighter in your house. Plasmas however don't have a setting to control how bright the picture is, so if you have a brightly lit room, it's not going to change much to how you see it in the store. In a dimly lit room, or completely dark, the plasma will have much more pop than what you see in the store, but still, it's not adjustable as it is on an LCD
post #4 of 13
brighter = hurts the eyes = headaches
dimmer = good
that's my equation anyway.
post #5 of 13
dimmer = good
I don't know about that. The brighter LCD made the colors more vivid and the whites were way whiter than the plasma's. It just looked cleaner and crisper. That's why I'm wondering if this is all the stores fault, and if I can get a better picture out of it when I bring it home. Or will it still be dim?
On a sidenote: The Samsung LNa650 seemed to have much better blacks than the Panny. What's up with that?
post #6 of 13
The Samsung LNA650's blacks are about the same as the Panasonic PZ80, but bright lights in the store will wash out a plasma. This is a because the plasma's phosphors are actually gray in color (like a CRT), while the LCD's screen material is black. In your house I very much doubt you'll notice this, unless you have a LOT of light coming in during the daytime.
The plasma probably won't look dim when you get it home. Those LCDs are incredibly bright in the store, you can't tell because the lights in the store are also bright. They'll give you a headache unless you adjust them.
post #7 of 13
Agree...unless I'm running my display in THX mode, I usually have it in a significant powersave mode, which causes it to dim a bit.
While LCDs are, in general, brighter, I don't know of any 2008 plasma that is too dim under normal home viewing situations.
That said, I would think that the PZ800u would make for a better comparison to the 650a.
Bottom line, both are great displays, and LCD does have its advantages, but you won't find many in this side of the forum who think those advantages outweigh the minuses.
pax,
rwr
post #8 of 13
I watch my tv in a very dim room. I have thick curtains for daytime viewing. If I go too bright like an LCD can, I need an Advil after 2 hours. That's why I chose a Plasma, as it is generally dimmer than LCD but superior in every other aspect, IMO.
post #9 of 13
I just went to Best Buy today and I noticed.......
And there ya go.
post #10 of 13
LCD's tend to be a little brighter than plasmas. And they will definitly tend to look brighter in stores than plasmas.
Some of it is the torch mode settings you are seeing in the stores.
Manufacturers set the TV's up like this so you will notice them more and they will POP out at you. Usually when people get the TV's home they would never watch them like this.
Most preferr a natural picture over an overblown, overbrightened image.
But some like it that way.
Personally I would rather have accuracy.
As another member stated once (can't remember who),
In real life Grass is not glowing, Roses are not hot red, and the sky is not super Blue.
It may be more flashy that way but I preferr an accurate depiction of the movie scenes. But there is definitly nothing wrong with watching your set that way if thats how someone likes it.
post #11 of 13
I couldn't agree more.
post #12 of 13
While I agree that plasmas are plenty bright, I don't think that a very bright display is necessarily "inaccurate." While there are guidelines for brightness settings (usually 30-40 footlamberts for direct view displays) those are usually meant to minimize eyestrain. Beyond that brightness levels are pretty much arbitrary.
post #13 of 13
I didn't mean that all LCD's that are bright are inaccurate. I was referring to the way they look in "torch" mode. That goes for plasmas in torch mode also. Some LCD's are accurate and bright.
