AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Why will Y/CR/CB not work on my Y/Pb/Pr Lcd
post #1 of 6
I bought a Sanyo DP32648 the other day, and while trying to hook up my XBMC modded xbox via Y/Cr/Cb cables all i get is no signal. I do however get sound. When I hook the xbox up to my Toshiba rear projection 53HX71, it works fine. They both have Y/Pr/Pb connectors. Any thoughts guys?
post #2 of 6
From the information provided the only logical conclusion is that the XBox is good and the Sanyo is bad. I assume the cables and connections to the Sanyo are correct and you selected the correct input. By the way the Y/Pr/Pb video connection is called the component video input. You need to try another device with a component output such as a DVD player or connect the XBox to another component input on the Sanyo and see if either works.
Generally the more combinations of connections you can try will provide us a better chance to help you.
post #3 of 6
What resolution is the Xbox outputting, and is it set to component colourspace or RGB colourspace?
post #4 of 6
i tried 480p and 720p and nothing but sound. took my dvd to the tv and it works nicely. Not sure about the component colorspace or rgb, where in the settings can i check that? looked and didnt see it.
post #5 of 6
Ok guys, thanks for the help, but found the problem. MonsterCable was so hard to get to seat properly. I had to push so hard. After i got it on works np, so tyvm
post #6 of 6
^ i hate that monster cable, i thought i was going to break my tv every time i unpluged it.
the oem xbox cable is alot better
