Originally Posted by evilstuie82
Now that I've done that... any ideas why my vista was bitstreaming DD EX Dolby 6.1 and another format to my AV for a while?
It may have just been with powerdvd, and maybe it was downsampling, but does the card still bitstream in xp, just with downsampling or not at all?
It has since reverted back to just saying multichannel on the display, only other options i can access is pure/direct (same deal) or thx (same again just different EQ)
I'm on XP so this is guesswork to a degree...
Ok, if you go into Control Panel>Sound, then for the Xonar Properties>Supported Formats, are the DD/DTS formats ticked to passthrough? Under Configure in the same spot are you set to 7.1 (or whatever)? Also tick Exclusive Mode for good measure
In PDVD 7.3 at least, I have no option to select hdmi, everything is multichannel. But try a dvd in MPC and see if it passes through the DTS.
