Originally Posted by mpgxsvcd
A more helpful comment would be This card is junk because it does not bit-stream DD-True-HD, it does not bit stream at all with Vista, it does not offer proper video calibration control in TMT, it will not pass 1080p @ 24 FPS video through it, it will not send PCM audio exactly the way it is encoded unless you manually select the correct Khz, the packaging for the daughter card is non existent, and all Dolby formats are incorrectly processed in TMT. Did I miss anything?
Other than that this card freaking rocks!
Sorry, your right. I should have said all you did which was much more helpful because it detailed all the failed promises of what this card was supposed to do, yet does none of it.
I actually messed up again when I said RMA is the only answer, because unless people bought from places that will give a refund, they probably will just replace it with the same worthless junk.
I agree with everything you said and stand corrected.
Thank you.
My heart goes out to all the hapless souls who purchased this cr*p.
dudeman
This has been a way of thinking for me for years; I appreciate good sound but refuse to get caught up in the hype surrounding audio. I have a top-notch system that can run with the best yet cost me a fraction of what many pay for similar sound quality (this is helped by having designed and built my own speakers for roughly 1/5 the cost of comparable commercial speakers even including the 8-channel amps and active crossovers required for each pair).
