Originally Posted by marchewd
Andy hit it on the head, you cannot apply DSP settings to LPCM. So, LPCM bypasses my Audyssey Pro calibration. Even with those things turned off in my 886 and the volume turned up, DD and DTS just sounded more dynamic. It could be the setup, it could be other things. I don't really care what the cause of it is. I just want to try bitstreaming the HD codecs to see if that solves the problem, which is why I placed an order for the Xonar. As for the analog section of the 886, 9.9, I never said it sounded terrible. It doesn't, it does a fine job. When I compared analog CD through the 886 to my Tube pre-amp, there were slight differences only. I was pretty surprised at how close it came to my Transcendent Sound 2-channel pre. I have been extremely pleased with the 886, which replaced an Outlaw 990. It has been a worthwhile upgrade. When you spend a lot of money on components, you just want to get the best sound and picture possible.
I need to point out a distinction. I was talking about analog signals from the player, since xgecko brought it up. That is different from LPCM as we refer to it here. When we say LPCM is the decoded LPCM coming digitally through the HDMI cable.
There are most probably other reasons as to why bitstreamed audio may sound different. If you have set your PC to output at higher than 48kHz, for instance, as probably most of you are doing, some of the Onkyos don't apply Audyssey for signals above 48kHz. So, when you bitstream, the audio is probably at 48kHz since not too many discs come with 96kHz audio (if you're bitstreaming regular DD/DTS bluray/DVD movies, it will always be at 48kHz or less). That's only one way in which the difference could be accounted for. Certainly bitstreaming vs. decoding in player is not the only reason it could be, and not the most probable either.
It's OK if bitstreaming is your MAIN (and I stress MAIN) purpose, but for my purposes, it's not such a great thing. I'll be returning it unless something changes DRASTICALLY with the drivers (very unlikely considering PAP).
