Originally Posted by Gamerphile
I can't seem to find anywhere that sells these or has them in stock. Newegg says "this product is currently unavailable" not just the usual "out of stock".
where can I get one online from a trusted retailer?
also, will this card work well for gaming. i just want a digital connection to my AVR that supports 7.1 channel audio so i can use all my receiver's processing abilities and Audyssey functions. Its my understanding that when using 7.1 analog inputs on my AVR it will bypass all the dolby processing and features which seems to me to be the point of modern surround sound receiver. is this true?
I am clueless when it come to digital audio. i just want the 7.1 surround for gaming, but want the receiver to do all the work when it comes to adjusting all my speakers for really good sounding surround sound. The way I understand it, if I use analog outputs from my sound card to my AVR i will have to manually adjust everything from the PC to get the surround sound set-up and sounding properly, negating the AVR's ability to adjust all the sound parameters. Am I correct in asuming this?
I just did a Bing search and had several good e-tailers come up that are selling them. Fry's seem to have several Xonar cards still but non of the HDAV ones.
It works great for gaming, for the games that don't use formats supported by your AVR the card has DD live and DTS interactive so it will convert the unsupported surround sound to one of these that your AVR will support to give you proper digital surround sound. You can also passthru digital audio, I have mine set up to do this for all my media play back and just use the Xonar's DD/DTS encoding for games.
