AVS › AVS Forum › Video Components › Home Theater Computers › *Official* Asus Xonar HDAV1.3 thread
*Official* Asus Xonar HDAV1.3 thread - Page 314
post #9391 of 9499
Originally Posted by Davinleeds View Post
use 1920x1080
Right, or separate connections.
post #9392 of 9499
It works!!! On TMT with BluRay Discs...
Now, with mkv and MPC-HC? Nothing has changed, no HD Bitstreamed audio...
post #9393 of 9499
I'm not sure but maybe TMT and mpc-hc don't support HD audio in an mkv container via hdav? Try demuxing the mkv to an avchd format and see what happens.
post #9394 of 9499
MPC-HC works. Last time I tried was with asaudiorenderer.dll from TMT5 .185.
post #9395 of 9499
Through the HDAV?
post #9396 of 9499
Through the HDAV?
Yes.
post #9397 of 9499
Originally Posted by Tulli View Post
Yes.
I should have added bitstreaming? I can see lpcm. If so, first I've heard. Thanks
post #9398 of 9499
Yes, bitstreaming (MPC-HC). But like I said, up to TMT5 .185 asaudiorenderer.dll. Right now I don't have the HDAV1.3 installed to test with latest versions.
post #9399 of 9499
Nothing... all it's right setted (seems to...) but I get HD bitstreaming only with TMT and BD... .mkv and MPC-HC nothing, only normal DD and DTS
post #9400 of 9499
Can you please post screen captures of MPC-HC output and external filters window and of the active filters during playback (right-click on MPC-HC window and select "Filters")?
post #9401 of 9499
Of course System Default Audio Device is 2: Altoparlanti (Xonar HDAV 1.3 etc.)
post #9402 of 9499
Ok, that looks perfect. The problem is, now that I remember well (I don't have my HDAV1.3 installed right now), that you definitely require ffdshow audio decoder which must be configured according to my previous post in this thread.
Only use ffdshow audio decoder instead of LAV audio decoder and it should work now ...
post #9403 of 9499
Thank you! I try now and let you know
post #9404 of 9499
nothing...
EDIT: DTS-HD from an mkv... now try other things
EDIT2: If I get DTS-HD audio the video is blocket, if the video runs audio is blocket
post #9405 of 9499
If it still doesn't work try using MPC-HC native splitter (Gabest) instead of LAV Splitter.
post #9406 of 9499
nothing...
hmm ... maybe using ffdshow video decoder instead will fix it. In fact this is the formula that used to work (mpc native splitter, ffdshow video + audio decoders & asaudiorenderer.dll).
post #9407 of 9499
MPC Crash...
so sad...
post #9408 of 9499
MPC Crash...
so sad...
Use latest versions of MPC-HC & ffdshow from www.xvidvideo.ru or from here.
post #9409 of 9499
done...
post #9410 of 9499
Need some help from the Xonar gurus.
Looking at buying a Denon 5805 receiver for a good price but it won't pass through 1080p
Can I feed the receiver audio out of the zonar hdav and feed my projector separately out of my video card or use a hdmi splitter to go to both?
Or can I simply come out of the video card's hdmi to receiver and the hdmi to the projector?
Cheers.
post #9411 of 9499
Cheers.
If you're using Win 7 and the hdav comes with a short dvi-to-hdmi cable, connect your video card's dvi output to the hdav's hdmi input. Connect the hdav's hdmi output to your Denon. Connect the video card's hdmi output to your projector. Make the projector display 1 and extend your desktop to display 2 which would be the Denon.
post #9412 of 9499
I'm still on Vista, there's an advantage to 7?
post #9413 of 9499
how I do it with my Onkyo's is using a small 19" monitor as 2nd display out of the HTPC DVI & then run outta the HDAV into my Onkyo then on to my display if your Denon has 2 HDMI outputs the you could also have a PJ & display as well .
make sure that the Denon is the primary monitor in windows .
the real benefit from this set-up is being able to switch to other video & still see the desk top on the 19" as when I switch to another source on the Onkyo the 19" then changes to the primary desk top on the HTPC ,, IE; watching DirecTV & still have the HTPC desktop on the small 19" . then when I switch back to the PC selection on the Onkyo boom windows 7 then adjusts agin & brings back the desktop to the large display , with the 19" going to 2nd extended monitor
It's all very cool as when watching streaming Vid's on the main display I still can use the 19" to surf for more content . change my mind to watch TV agin boom automatically goes desktop to 19" as primary .
post #9414 of 9499
I'd say all around.
post #9415 of 9499
I'd say all around.
+1100
uses less resources , less buggy, WAY better home networking , easy to use ,FAST
post #9416 of 9499
Damn! More upgrading.
Home premium ok?
post #9417 of 9499
Home premium ok?
Yeah , go with NewEgg to purchase it's on sale all the time
back everything up & do a complete new install not an overlay .W7 will ask which one that you want .
post #9418 of 9499
Cheers.
post #9419 of 9499
Another quick Q if anyone knows, will the HDAV 1.3 Slim work with the H6 analog daughter card?
post #9420 of 9499
No, you'll need a standard HDAV1.3.
