AVS › AVS Forum › Audio › Speakers › Pioneer CS-R590
Pioneer CS-R590
post #1 of 4
Hi all
After my recent loss of crap speakers to high volume ordeal, I am on the lookout for new speakers. Does anyone know anything about the Pioneer CS-R590 speakers? Google doesn't seem to help much.
post #2 of 4
there old thats all i can find about them
if your looking for cheap very good speakers and you have a sub or can get one try the B.I.C venturi DV62si there about $100 on amazon
post #3 of 4
Honestly, they are junk.
I bought a pair at Goodwill for for five bucks for the pair. I had some delusion that they would make passable garage speakers.
I gave them back to Goodwill after a week. I even upgraded the crossovers.
I went back to my self designed car audio abortions for better sound in my garage.
I would never recommend these speakers to anyone for any reason.
post #4 of 4
If you're looking for a cheap bookshelf speakers take a look at these.
http://www.parts-express.com/pe/show...number=300-652
What is your budget for two speakers?
  Back to Forum: Speakers
