I'm trying to help a friend with his DELL flat screen tv. He currently uses the "PC Line in" for audio input from his ipod. The audio plays fine through the TV speakers but, the problem is the TV has a (SELF TEST FEATURE CHECK) bouncing around the screen. This annoying color box isnt that big of a deal, but the main problem is we are unable to change the volume. This TV wont let you change the volume up or down unless their is an active video signal. This means we have to change the input back to TV tuner before we can change the volume back up and down again.
Q1) Does anyone know of a cheap device that will generate a fake vga signal so the tv stays fully active? (no matter how ghetto it is anything at all, as long as it's inexpensive)
Q2) Does anyone know VGA specs as far as shorting out specfic pins that will cause a blank out signal? (loop back etc?)
Again, the goal is to send a fake VGA signal to the TV so it stays on and the audio continues to play etc.
