AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Living Room Which Choice VSX-918 Or RX-V463
post #1 of 30
I am looking at getting new receiver for my living room. This unit does not need to be high end. I have a theater room for that. I am using a Polk surroundbar and a 50 Panasonic plasma all wall mounted. I have an HDMI cable ran in wall from the receiver location to the Panasonic as well as 5 runs of 14ga speaker wire for the surroundbar. For my sources I am using just a Direct TV H20 and that's all for now. But I do plan on adding a Blu Ray player down the road maybe. I have a subwoofer located at the receiver location as well.
My needs are this I need something that will upconvert to HDMI and will also pass audio over the HDMI. It will also need to have a subwoofer out as well to power my existing KSW10 The new unit doesn't need the new audio codecs I will just be using it for casual viewing.
So which unit in your opinion will fit my needs better. I am torn between the Yamaha RX-V463 or the Pioneer VSX-918V. Thanks everyone
post #2 of 30
i'm down to the same 2 receivers you are. anybody? do they both pass HDMI without clipping?
post #3 of 30
bump, come on please chime in.
What do you think is better? Hooking up PS3, Toshiba A3 HD-DVD, PC, going to Panasonic 50pz85u Plasma. With my room I'm only able to get 5.1 setup. I don't want to spend more than I have to. They can both be had for the same price. do you know if the 463 has problems with btb or wtw? does the 918 have problems producing bass from a 2 channel source using cd input?
post #4 of 30
OK. Here goes:
VSX-918 - Weak on bass, weak on power.
V463 - Probably has btb and wtw issues, BUT that's only really problematic if you've a HTPC.
If I HAD to choose, I'd go Yamaha, and would stare longingly at the 663...
post #5 of 30
Why is the VSX-918 week on bass & power?
I'm looking hard at the VSX-918 since it's priced low at Newegg.com for $249 right now.
It rec'd a good review from hometheatermag.com. It passes PCM over HDMI which is nice for a receiver at this price point, although it doesn't have the latest codecs like DTS HD and Dolby TrueHD. It has 120W per channel (actually 95W) and low distortion (0.05% THD) and decent S/N ratio of 98 dB, so I'm curious to why you say it's weak. Have you heard both with your own ears? Similar equipment, settings, room, etc?
post #6 of 30
It rec'd a good review from It passes PCM over HDMI which is nice for a receiver at this price point, although it doesn't have the latest codecs like DTS HD and Dolby TrueHD. It has 120W per channel (actually 95W) and low distortion (0.05% THD) and decent S/N ratio of 98 dB, so I'm curious to why you say it's weak. Have you heard both with your own ears? Similar equipment, settings, room, etc?
I was also doing some research on both the V463 and VSX-918.
Reading customer reviews around the internet, I found one on amazon.com that had an issue with cd 2 channel low bass with the VSX-918:
"I guess I went into the purchase of this receiver with expectations set far too high.I have owned Pioneer receivers for years and was saddened by the death of my Pioneer vsx-608D.I really liked that unit alot.It came out in 1999.It did have Dolby Digital 5.1 sound with DTS.When I got this new 918 hooked up I was very happy with the sound of Dolby Digital and DTS movies.They sounded fabulous.I do however like to listen to music alot.When I switched to the cd input I thought my powered subwoofer had stopped working.I tried everything I could think of to get the bass level up.I made sure the Plus setting was turned on.This setting makes sure that bass signals sent to the large front left and right speakers are also sent to the subwoofer.I ran the auto set-up where you hook a microphone up to the system and it goes through a series of test tones to determine the best set-up for your room.Well,after going through this, all I heard was a trace of bass.I turned on the midnight setting and noticed a positive result.I tried the loud setting and it too made a more noticeable difference in the output of my subwoofer.The midnight setting however was better to my ears.It sounded like the subwoofer was putting out very little bass.I finally called Pioneer customer support and they ran me through a bunch of settings trying to get to an answer to my problem.Nobody was able to tell me anything that could explain the cd input's lack of bass.Finally I was told to take the unit back and exchange it because I had probably gotten a defective unit.After getting my new 918,I was saddened to find out that I was stuck with the exact same problem.I again called tech support and this time was told that the 918 was not designed to play cd's with stereo sound.I was told that it just wasn't capable of outputting a good bass signal to the subwoofer.I couldn't beieve my ears!!He said that this model is designed as a home theater receiver to decode 5.1 Dolby Digital and DTS.It is "not designed for 2 channel music".I just don't understand why this unit can't do both.Why did they bother to even put a cd input on the amp?I ended up taking the 918 back and trying a Yamaha model RX-V463.What a difference.I can hear my 5.1 and DTS movies with plenty of bass but more importantly,the Yamaha puts out great bass to the subwoofer for great sounding music cds recorded in stereo.I'm through with Pioneer although in all honesty it had fantastic Dolby Digital and DTS sound.This one issue over music cds ruined the Pioneer experience for me.Pioneer 120 Watts X 5 Hybrid Receiver"
post #7 of 30
Had a question.
First, my set up is/will be in living room, so not the best for audio.
Samsung 61 A750 DLP (Future purchase, in November)
Xbox 360 60gig hdmi
PS3
and Dish HD turbo (haven't got, yet waiting for TV)
5.1 setup. Need to upgrade my speakers, but mostly will be for watching movies and some music.
If I get the V463, will there really be anything lost if I hook up my xbox through component and optical?
Also, I could upgrade to 7.1 setup, but am I really missing out at this point, and given this is not a dedicated room?
post #8 of 30
Based on a the glowing review from http://hometheatermag.com/receivers/808piorec/, I would go with the Pioneer.
Edit: I just read a good review of the 463 too. http://hometheatermag.com/receivers/1008yamrec/
post #9 of 30
no problems here. I received my Pio 918 Monday and it's sweet! No problems with low bass, in movies or cd's, Toshiba HD-DVD a3. also, have my sirius player hooked up in AUX, and no bass loss. I'll try the cd input this weekend to make sure. I'm thinking that the guy from amazon didn't set it up properly. I bought mine from newegg, ordered it late Thursday, free shipping. no regrets.
post #10 of 30
Thanks for the comments guys. Tony, look forward to hearing your results from this weekend. Was looking at the pioneer at amazon, but have an account with newegg, so I'll see what their price point is, too. Thanks
post #11 of 30
no bass lost, the guys on amazon are just stupid. i had no issues, connecting to the other ports. this is a great receiver for the price.
post #12 of 30
That is great to hear. Thanks
post #13 of 30
I don't think NewEgg is an authorized Pioneer dealer so they may not honor any warranty issues that might come up. Check out 6th Avenue as they're authorized and if coupon code "Fall101608" is still working, the 918 is $248.39 shipped.
post #14 of 30
Phone support?
What guy..
post #15 of 30
Thanks for the info on newegg and 6th avenue. I probably stick with amazon since I get free shipping with amazon prime and they just lowered their price on the vsx-918.
post #16 of 30
Any of you guys with this receiver run the lossless codecs through it? If so, what setting do you put the receiver on and what does the front panel say? Does it actually say (DTS-HD, etc. or does it say LPCM?)
post #17 of 30
Don't worry about the receiver settings; that will take care of itself. It will say LCPM or Multichannel because that is what it sees. Check the source to see what is being sent. These receivers can't process HD Audio via bitstream so LCPM via HDMI is the only option. Also, most low to mid range BD players can't bitstream HD audio.
post #18 of 30
Finally hooked up my receiver and ran the auto setup MCACC and it sounds like there is no bass coming from my sub? I have some crappy klh speakers and sub, but the bass was a lot harder hitting with my old home theater in a box klh receiver? Should I run the setup again? I have to put it around -35 to get the lcr speakers to be loud enough, and even then the bass is almost non-existent.
post #19 of 30
I have ran the MCACC on my Pio 918 and it works just fine with 5 Polk sats and 1 8" Mirage subwoofer. I am loving that AVR.
Just my 2 cents
post #20 of 30
Hello everyone,
I'm planning to buy budget AVR and I'm considering Pioneer VSX-918 and Yamaha RX-V463.
Since I'll also use it for music, I was wondering which one is better for stereo? I can get them for around the same price.
Also, is problem people reported regarding Pioneer's low bass volume real or was it reported due to bad setup?
post #21 of 30
When you run MCACC, be sure the gain/volume on the sub is 1/3 to 1/2, the ON, AUTO, OFF switch is set to ON and crossover is set to the maximum.
If you want more bass after MCACC, just tweak the volume knob up a bit. Many like a lot of thump, but MCACC will set it more acoustically correct.
post #22 of 30
Does anyone know what hdmi version Pioneer VSX-918 has?
In fact is it possible to connect different hdmi versions. 1.3a in LCD Panel and 1.2 in AV-receiver, for example?
I am planning to use it with small Jamo speakers with 6 Om and 60/80 Watt per channel. I hope switching to 6 OM in Pioneer VSX-918 works fine. I haven't bought AVR Sony-820 only because it woks with 8 Om.
post #23 of 30
Thanks. I ran it again and change the gain/volume on the sub to 1/2 and that seemed to work wonders. Sounds a lot better now. Hopefully, in the next couple of days I will be able to upgrade my speakers. Looking at purchasing a 5.1 setup of acculine speakers. http://www.theaudioinsider.com/manuf...s.php/mPath/13
The only thing I'm concerned about is the the A2 and A3 are 4 Ohms and the 918 is only rated for 8 and 6 ohms.
post #24 of 30
I'm not sure what HDMI version it has, but all I know is that you only need one hdmi to get video and audio. It also states that you get PCM via HDMI.
http://www.pioneerelectronics.com/PU...V-K.Kuro?tab=A
I have my ps3, xbox 360 hook up through hdmi out to my tv and it works just fine.
post #25 of 30
Thanks for reply
Do you think this is highly dangerous to use together receiver rated higher then speakers?
6 with 4, or 8 with 6
post #26 of 30
Thanks for reply
I'm a newbie when it comes to speakers and receivers, but what I researched some and it seems that the pioneer would be find running speakers rated at 4ohms, just that you couldn't max out your volume, which most people wouldn't plan on doing anyways.
I did a search in the speaker forum and came up with this thread.
http://www.avsforum.com/avs-vb/showt...aker+impedence
Basically, saying it is alright to have 4 ohms speakers with a receiver rated for 8 and 6 ohms. It was recommend to me in the acculine owners thread on these forums to just set your receiver for 6 ohms.
Also, the watts per channel on the 918 is more than enough to power lower impedance speakers. I believe it states that the 918 is 120w/channel, and I read in my owner's manual that it is rated at 95w/channel.
post #27 of 30
I also found a website trying to explain speaker impedance. I don't really understand it all, but it might shed some light on the subject.
http://www.roger-russell.com/wire/wire.htm#wiretable
Nominal Speaker Impedance
A nominal impedance value is not always accurate because most systems vary with frequency. A speaker that is rated by the manufacturer as 4 ohms may not be 4 ohms at all frequencies. It can wander above or below this value and is unique for different systems.
post #28 of 30
Does the 918 pass BTB and WTW via HDMI?
post #29 of 30
Anyone?
post #30 of 30
Originally Posted by MidnightWatcher View Post
Anyone?
I've had no problems when watching bluerays on my ps3, but to be honest how would you know if your were having btb/wtw issue? I have a panny pz85u plasma and have had no problems with 918. The only issue I have had was with the auto setup and bass, which was quickly solved by re-running the auto setup and ajusting the bass level. Works great now.
The only problem I see is that I eventually want to get an avr with preouts and an external amp, (looking at Emotiva xpa-5), so I can have more power, and greater flexibility in the future. Just don't tell my wife.
