AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Key fell off of Harmony 880 - what to do?
post #1 of 7
I have an out of warranty Harmony 880 remote. The 'menu' button has come loose and fallen off. I have the button and it is in one piece.
How are these held on for me to fix it? A bit of glue? Something else that glue won't fix?
I don't want to just glue it if that won't fix the problem - it's a permanent non-fix in that case.
Any help?
Andrew
post #2 of 7
Any help?
Andrew
Why not call Harmony? I've found them to be pretty helpful, even with out of warranty stuff.
post #3 of 7
I have called them and logged the problem.
But at the same time, if it's an easy fix; someone here has probably done it. I really don't need them to send me a new unit for one key if it is reattachable (was that a word before now?).
Andrew
post #4 of 7
Is it less than two years out of warranty? If you paid with a credit card you may be covered. I just replaced an external hard drive and got a laptop fixed that was purchased with two different Visa cards.
If it was like the hard drive, once authorized you just buy a replacement, mail the defective unit back to them, and fax the receipt.
post #5 of 7
Well, I got an email from Logitech; it seems they didn't care about the loose key. They cared that the battery didn't seem to want to charge.
They are disabling the current remote from their system and sending a new unit out.
No charge.
Since they can lock out a remote from their system, they don't even want the old remote back.
Andrew
post #6 of 7
See, great customer service. Harmony is usually pretty good about stuff like that.
post #7 of 7
i also need to know how the f do you reattach a key, i got 3 that have come off, my base was replaced a while ago, otherwise unit is fine, yeah I am aware I revived a 550 day old thread, just give me an answer lol
  Back to Forum: Remote Control Area
