AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › Sunkey SK-801ATSC
Sunkey SK-801ATSC - Page 6
post #151 of 200
Is there still any review available. I want to try this.
Simulation pret
post #152 of 200
Review? Have you read through this thread?
post #153 of 200
Originally Posted by marknyc5 View Post
Just installed the SK-801ATSC here in Queens, NY, and the signal reception with just a pair of rabbit ears is amazing! 21 stations clear and strong.
The only problem seems to be with the connection from the box to the set. I'm using the RF adapter and there's a lot of snow. This is not from the reception, since the snow appeared on the setup screen before any signals were found. It's consistent on menu screens and on TV channels.
Any idea on what could be causing this? I've tried channels 3 and 4 with no change.
I ordered 2 apparently about the same time as you and I have the same problem in both. Testing convinces me that the problem is internal to the box
post #154 of 200
Had the same problem with mine NOISY power supply (wall wart).
Called the place where I got the unit and he gave me an 800 number to call.
They sent me a replacement wall wart (different style) pretty quickly and that solved the problem.
post #155 of 200
Mind giving those of us with the Sunkey (aka Craig) unit the number?
post #156 of 200
thanks for the info!
For anyone else with this problem, a temporary workaround if you have one of the newer analog TV sets with several sets of RCA inputs (The red white and yellow cables usually used to connect video game consoles) is to, instead of using channel 3 or 4, connect your Sunkey through the RCA cables only and then change your TV's video mode to accept input from the alternate source.
Unfortunately I don't think there is a way to put one's VCR in the loop using only RCA cables
post #157 of 200
It's lost in the mess on my desk or I no longer have it.
The number was to the specific supplier who provided product to where I got my Sunkey... freetvsignal.com
If you got your Sunkey from freetvsignal.com then ring them up or email.
If you got your Sunkey elsewhere contact that seller.
post #158 of 200
Just got my SK-801ATSC along with an Artec T3AP-LS from FreeTVSignal.com. It only took four days (which included a weekend) from ordering to having the CECBs on my doorstep. Pretty nice considering it was completely free and I didn't even need to give a credit card number. My SK-801ATSC says it has Software Ver. x1.00-112108A, though I don't see any differences in the menus from the photos that were posted earlier in this thread. (To be clear: This box still just has the simple one channel now/next guide.)
I can't comment on the RF interference issues, as I had it hooked up via RCA composite cables, and the picture quality looked good overall. I did test to see that the power supply from the Artec unit does work fine with the Sunkey. The Artec unit's power supply says it is 12V/0.5A where the Sunkey one is 12V/0.8A. But, as I said, they appear to work interchangeably. I believe these are also a couple of the only units that will work hooked up to a 12V battery, which is what I was intending for them.
As for reception, it gets all of my local channels in perfectly with a signal between 80-90%, and a quality of 100%. But I intend to take these two boxes to a place where there is very sketchy signals, so I will be able to see which performs better then.
One big positive for the Sunkey is having the channel buttons on the box. Since I'll only have a couple of channels available, using the remote may be unnecessary. One huge drawback of the Sunkey unit is the menus look like garbage. The fonts are tiny, and since I wanted to use this on a 13" TV, I probably won't be able to even see the channel numbers at that screen size. The Artec unit is much better in that respect, and is probably one of the nicer CECB's I've used. But reception is everything for my purpose, so I will test both soon and report back my findings.
post #159 of 200
I've been troubleshooting a a noise issue on a TV with analog cable for a couple of weeks now. I finally isolated it--it's the awful Sunkey wall wart (I can plug it in--without connecting it to the converter box--and immediately see the interference on low analog TV channels)!
I called them (http://rjtech.net/info.php?catId=246&f=repairRequest) and the tech promised to send me a new wall wart via UPS.
[Just FYI, contact info for all CECB brands is available from this government website: http://www.dtv.gov/converterbox.htm ]
post #160 of 200
Any ideas what the new power supply looks like? I am not sure if I am affected.
post #161 of 200
The one causing problems for me and others is model SKCH06-1210 with the date code 2008/08 on the sticker.
post #162 of 200
You do know that this problem was reported earlier in this thread?
post #163 of 200
Yes. I was providing the Sunkey contact information which was heretofore not included in the thread.
post #164 of 200
Meritline has the Sunkey SK-801 on sale for $40.00 with free Mygica DTV antennae with free shipping...$0/free for any remaining dtv coupon holders.
http://www.meritline.com/sunkey-sk-8...ource=dealnews
post #165 of 200
No antenna (and I don't think gov't coupons are accepted), but it's also available for $32.99 from Happy Iguana.
http://www.tvconverterboxstore.com/s...og-pass/Detail
post #166 of 200
You know, that site has pretty lax security 'standards', since, if you follow the info they tell you about how to enter the coupon and such, they then transmit that exact info to your e-mail address... They should have masked out the coupon number, or do the last 4 digits like most other places do.
Which would mean, there is a chance that, that info can be captured... not that it matters much in this case, but still... Yeah, the site is listed as a authorized coupon partner, so I am just nitpicking.
Still a nice deal for people who can't find any decent converter boxes, and want to spend as little as possible.
post #167 of 200
Although I'm sure a lot know this,
and to NOT cross-post.
I would like to cross-link to
what APPEARS to be an identical offering.
The Craig CVD508
It is a basic technician tear-down and peek inside thread.
Note:
Although I have E-Mail'd them twice,
they fail to provide a link to their product...
post #168 of 200
Just an update--I received the new power supply. It looks exactly like the defective one (same model number, etc.). It, however, does not have a date code sticker, but, rather, an etched-in date code (sometime in 2009).
post #169 of 200
I was searching for DTV channels with the Sunkey..I only got like 5 DT channels..with the Insignia NS-DXA1-APT I got like 38 DT channels
post #170 of 200
That's an unusual discrepancy.
In fact, the only thing I like about my Sunkey box is its tuner. The remote, OSD, IR receiver, EPG, etc. are pretty poor. The tuner, however, is nice.
post #171 of 200
Well I'm using a Radio Shack Antanna with a Knob on it.I'm must be turning it to get a weak signal
The fonts are hard to see if your trying to scan on a 3 inch TV
post #172 of 200
I got in on this. Also came with a free HDMI cable.
I'm still saving my other coupon for a box with S-Video (is Apex the only one?).
Either way sure can't beat the price.
post #173 of 200
Originally Posted by Random Digital View Post
II'm still saving my other coupon for a box with S-Video (is Apex the only one?).
Channel Master 7000 and maybe a coupla others. I say "maybe" because I never of heard of these other ones on Wiki down the S-Video column:
http://en.wikipedia.org/wiki/Comparison_of_CECB_units
'Carefree?' I wonder if these are new adds to Wiki?
post #174 of 200
Originally Posted by Floydage View Post
...I say "maybe" because I never of heard of these other ones on Wiki down the S-Video column:
Yeah, I tried to open a dialog with that company about american retail.
They chose not to market in the USA, the profit margin was just to slim.
You can read the details in the thread I started about Those CAREFREE CECB's.
post #175 of 200
I got in on this, Also came with a free HDMI cable.
I have to go there...is that a joke?
I mean did they really bundle an HDMI cable with a CECB???
post #176 of 200
Oh yeah, I tested the power adaptor that came with my Sunkey for noise and I found none whatsoever. My adaptor looks exactly like the noisy ones too; except it also has its date code hot-stamped into the plastic. (090221)
Speaking of Sunkey, they're getting even more mileage out of those cases...
http://sunkey.manufacturer.globalsou...dia-Player.htm
Later...
post #177 of 200
Jackpot!
The merits of shopping at Meritline...
post #178 of 200
Not if you buy a Mygica...or MygicaS.
http://www.meritline.com/mygica-digi...ource=dealnews
post #179 of 200
This is from my reciept....
HDMI v1.3 Cable Giveaway Mygica Digital TV Antenna, A20 Indoor Digital TV Antenna, Black, For HDTV, USB/PCI Digital ATSC Tuner or DTV Converter Box, UHF + VHF Analog and Digital Frequency Range-Giveaway One 6 Feet HDMI v1.3 Cable
SKU:201-121-001 Ship in 1-2 Business Days. Most customers receive within one week.
post #180 of 200
Interesting. Too bad, sounds like it might have been a good box for 'US.'
Looks like you had better luck than I had trying to get production info out of Zinwell (Zinnet); vicious circle of telling me what I already knew instead of answering my questions.
