Originally Posted by
HogPilot
I'm going to see if he's willing to work with me on his prices, and if not then too bad. If he really thinks that he can get $10K for a used pair of SC-V's when I've never seen a pair of SC-VI's go for that much, he's going to be holding on to all of these speakers for a very long time.
I noticed that Carl re-posted his Dunlavy speakers yesterday, but unfortunately for the same exact prices he had asked for earlier (
http://cosprings.craigslist.org/ele/1588914102.html). The good thing is now he also posted the prices in the actual ad.
The best part though, is he included
specs for the lesser known models he's selling! I'll paste those here, so they're permanently accessible to anyone who might need them:
SC-1av
Arrangement 2 - way
Woofer (2) 5.5"
Tweeter (1) 1" soft dome
Frequency Response 75Hz - 20kHz, +/-1.5dB
Video Shielding Yes, standard
Dimensions 20"H x 8"W x 10"D
Weight 25 lbs
Sensitivity 91dB
Impedance (Nominal/Min/Max) 7/4/10
Retail Price $1,800/pr
Notes - Despite only 10hz more bass extension, the SC-1av sounds much fuller in the bass the the original SC-1 due to better woofers. Ideal in stereo or as a **lcrs in a 5.1 channel system with a subwoofer.
CC-1
Arrangement 2 - way
Woofer (2) 5.5"
Weight 25 lbs
Sensitivity 91dB
Retail Price $1,095/ea
Notes - This center channel speaker is identical to the SC-1AV except for a slight angle to the baffle board. This angle allows the CC-1 to focus the sound for optimum performance when placed below or above a television, or in a bookcase. It can also be used in any channel of a home theater as a **lcrs.
SC-2a
Arrangement 2 - way
Woofer (2) 6.5"
Frequency Response 60Hz - 20kHz, +/-1.5dB
Video Shielding Optional ($100/ea)
Dimensions 25"H x 11"W x 13"D
Weight 45 lbs
Sensitivity 91dB
Impedance (Nominal/Min/Max) 5/3/7.5
Retail Price $2,700/pr
Notes - This speaker is sonically identical to an SM-1. The model change was to avoid the confusion between the SC-1 and the SM-1. A large improvement in bass response and output capability compared to the SC-1AV. Enough bass for stereo listening or as an **lcrs with a subwoofer.
CC-2
Arrangement 2 - way
Woofer (2) 6.5"
Weight 45 lbs
Sensitivity 91dB
Retail Price $1,450/ea
Notes - This center channel speaker is identical to the SC-2a except for a slight angle to the baffle board. his angle allows the CC-2 to focus the sound for optimum performance when placed below or above a television, or in a bookcase. It can can also be used in any channel of a home theater as a **lcrs. The CC-2 has clearly superior bass response and dynamics compared to other similarly priced center channels, even at it's original price.
SC-3a
Arrangement 3 - way
Woofer (1) 10" (downfiring)
Midrange (2) 6.5"
Frequency Response 27Hz - 20kHz, +/-1.5dB
Video Shielding No
Dimensions 52"H x 11"W x 14"D
Weight 85 lbs
Sensitivity 90dB
Impedance (Nominal/Min/Max) 4/3/6.5
Retail Price $5,500/pr
Notes - Sonically identical to the Aletha and Cantata which were condensed down to this one model to avoid consumer confusion. The SC-3a's cabinet has rounded edges and a full length grille compared to the Cantata giving it a much more attractive streamlined appearance. This is the smallest and most affordable Dunlavy with truly full range bass. Most subwoofers can't go as low as the SC-3a!
SC-4a
Arrangement 3 - way
Woofer (2) 10"
Midrange (2) 5"
Frequency Response 25Hz - 20kHz, +/-1.5dB
Video Shielding No
Dimensions 72"H x 12"W x 18"D
Weight 190 lbs
Sensitivity 91dB
Retail Price $9,000/pr
Notes - This brilliant redesign of the famous original SC-4 extends the bass to 25hz with it's new Scanspeak woofers and crossover. It sounds much fuller in the bottom end with a noticeably warmer and smoother tonal balance than the SC-4 and is a major upgrade.
SC-S1
Arrangement Powered Subwoofer
Woofer (1) 12" downfiring
Amplifier 250 watt Class D Amp
Frequency Response 25Hz - 110Hz, +/-1.5dB
Video Shielding No
Dimensions 18"H x 16"W x 20"D
Weight 85 lbs
Retail Price $1,700/ea
Notes - Only a few of these were made. It uses a different 12" woofer than the SC-5 that is specifically designed for a much smaller box. We were lucky enough to audition a prototype in April of 2002 at our store and were able to hear it outperform the B&W and Velodyne subwoofers that sold for the same money
SC-S2
Woofer (2) 12" downfiring
Amplifier 400 watt Class D Amp
Frequency Response 23Hz - 110Hz, +/-1.5dB
Video Shielding No
Dimensions 18"H x 18"W x 30"D
Weight 105 lbs
Retail Price $2500/ea
Notes - Only a few of these were made. It uses a different 12" woofer than the SC-5 that is specifically designed for a much smaller box. We were lucky enough to audition a prototype in April of 2002 at our store and were able to hear it outperform the B&W and Velodyne subwoofers that sold for the same money.
Dunlavy's bass response cutoff's that we have quoted are at the minus 1.5dB point, and are taken in an anechoic chamber. An anechoic chamber is a reflectionless room, extremely heavily damped, used for measurement purposes only. It allows the room to be ignored leaving only the speakers performance behind. Most other companies quote the less stringent minus 3dB point measured in a room of their choice. This results in a much more impressive if less accurate and repeatable specification. Due to the bass gain resulting from room boundaries, add about 1/2 octave of bass for the minus 3dB point in a typical listening room. This means you will get significantly more bass in your room than the anechoic measurement suggests. Ie., depending on room setup, we were often able to measure the SM-1/SC-2a in room bass response to 40hz (-3dB point) despite a 60hz minus 1.5 dB anechoic cut off.
**lcrs -An abbreviation for a speaker that may be used with equal effectiveness as a left, right, center, or surround speaker. In a perfectly setup surround system, all 5, 6 or 7 speakers would be identical to achieve the most realistic sound stage. This is why the SC-1av is driver and cabinet matched to the CC-1 center , and the SC-2a is driver and cabinet matched to the CC-2 center. This is also why all Dunlavy models use the same tweeter and the drivers are all graded carefully so that there is no discontinuity in sound between channels.
