Venturing into the world of projectors. Due to limited placement in my basement, I need a projector with vertical shift. I will not be able to mount the projector either x" above or below the screen. Will have to be ceiling mounted and center of projector lense will probably be in line with top of screen or an inch or two below. From my understanding, I'll need an LCD projector?!?
I'll be going with an 85" screen, sitting about 11-12' away.
On a very tight budget so please offer up a couple of the least expensive options.
So far, I've looked at the Benq W500 because it can be had for well below $1,000.
Thank you.
Thank you.
