AVS › AVS Forum › Video Components › DVD Players (Standard Def) › Panasonic DVD Firmware Update 200405 ISO
post #1 of 5
I am trying to upgrade my dvd rv-27, so I managed to download this iso. I tried to burn it, both on dvd and cd, but when I put the disk in my dvd it says that it is an unsupported disk and won't play it. Can someone please tell me what I'm doing wrong?
post #2 of 5
Make sure you are burning it as a disc image, not as a data file.
-Bill
post #3 of 5
I found instructions that said to do both, so do both I did. I burned the image (cd and dvd), pulled the files and folders off the .iso and burned them (cd and dvd), nothing seemed to work. My dvd would spin for about 3 minutes and then say unsupported disc or somesuch.
post #4 of 5
Are you using Windows? I've seen this utility recommended for burning ISO files: http://www.imgburn.com/
Have you used this media with this player? Could be they are not compatible. You might try a different brand.
-Bill
post #5 of 5
Where did you find the file - I am in need of it as well. A link would be appreciated.
D
  Back to Forum: DVD Players (Standard Def)
